Question about Motorola Mobility L6 Cellular Phone
L6i my Initial Setup cannot open in the settings. how will edit the set-up?
  • Anonymous Dec 20, 2007
    i cannot open my initial set up
    Brigadier General:
  • 7,752 Answers
Do a master reset on the phone to correct that issue...if that does not help, take the phone to a mobile service center and have them reflash the phone's firmware.
Posted on Jan 19, 2008
My motorola c350 language has been changed. Now I cant read the language for what its getting difficult to change it to English. Please help
Download the user-manual from this site. http://www.motorola.com/mdirect/manuals/C350_gsm_User_Manual_E.pdf
Observe the menu map. From your main menu, you have to open more (It has box open icon). Under More, you have to open Settings(Two mechanical bolts icon).
Under settings, you have to go to Other Settings which is the 5th option.
Call Forward
Phone Status
In-Call Setup
Security
Other Settings *
Under Other settings, you have the following options:
Personalize
Initial Setup
Network
Car Settings
Headset
You have to select the 2nd setting, that is Initial Setup.
Under Initial Setup, you have the following options:
Time and Date
1-Touch Dial
Backlight
Zoom
TTY Setup
Scroll
Animation
Language
Battery Save
Contrast
DTMF
Master Reset
Master Clear
You have to select the 8the option, which is language(langua/idioma/langue).
Now from the options select English to set english as the changed language.
Jul 20, 2011 | Motorola Mobility C350 Cellular Phone
I cannot change my Motorola L6i back to English.
1)Go to menu/setting/initial setup/language/chose English press ok.or
2)Menu/setting select/navigation key down 5 times/initial setup press change/pess navi key down 5 times,press change,then select English press change.hope to solve problem.
Aug 16, 2009 | Motorola Mobility L6 Cellular Phone
Initial setup in My Motorola L6i is not working
In My Motorola L6i intial setup is not working. How to solve this problem???
Jun 23, 2009 | Motorola Mobility L6 Cellular Phone
Do not open initial setup in the motorola l6i mobile
May 20, 2009 | Motorola Mobility L6 Cellular Phone
No sound in edit view
Well, the settings in edit view and mutitrack view are not, unfortunately, the same... you can set them the same, but it's not that way by default.
I haven't used 1.5 in a while, but my initial guess is that one of these are true:
  1. You've muted audio play-back on the edit view
  2. You've disabled monitoring on edit view
  3. The playback source in edit view is set to the wrong hardware.
  4. I believe there was a playback volume controle even in 1.5.  If so, you could have actually turned the volume all the way down for playback..
If I get a chance later this afternoon, I might try reinstalling 1.5 and seeing if I can get figure it out on that version.
Post back with your results so far.
Also, it'll be helpful to know what version of Windows you're using.  In Windows Vista, there's a volume mixer where you can control the volume for any open applications as well as Windows sounds - different than the typical mixer setup in XP and prior.
Jan 06, 2009 | Adobe Audition 1.5
Motorola format
go to MENU then SETTINGS then INITIAL SETUP then MASTER RESET (000000) OK.
Nov 10, 2008 | Motorola Mobility L6 Cellular Phone
Formatting
MENU>SETTINGS >INITIAL SETUP>MASTER RESET>(000000)>Ok
and after that,
MENU>SETTINGS >INITIAL SETUP>MASTER CLEAR>(000000)>Ok
I need help
you have to do to setting, initial setup, theng look for master reset.
Jul 18, 2008 | Motorola Mobility L6 Cellular Phone
Initial setup wont work
you need to have the phone's firmware reflash so take it to a mobile service center and have that done.
Nov 16, 2007 | Motorola Mobility L6 Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
43 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
