Question about Casio AWS90D-2AV Wrist Watch
Casio broken
My friend has a casio mens all balck watch. the clasp is one of those that click closed, not a buckle. the little peg on the clasp that it clicks onto has broken off. is there a way to reapir it or should he just buy a new one?
  • Anonymous Mar 14, 2014
    clasp for kc3789 mens
  • 14 Answers
The band must be replaced, that part is not replaceable. Sorry.
Posted on Dec 05, 2007
How do you remove a link off the Casio Men's Edifice 10-Year-Battery Analog Bracelet Watch #EF106D-2AV?
Have a look at the links nearest the clasp.
These should have markings on to say which are removable. An arrow or some other indication.
Not sure if this watch has press pins that go through the whole bracelet or flip up catches on each band.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 01, 2011 | Casio Edifice 10YearBattery Bracelet...
How to exchange leather straps for almost any watch brand
Most of the people are pretty sure that when their watch leather straps are worn out they have to replace them with new ones, made by exactly the same brand as their watch brand is. This is completely wrong. About 95% of all watch brand models can be fitted with leather straps from any watch strap producer without loosing brands identity. All you have to do is: 1. Release the strap from the watch; 2. Measure the width of the strap where the spring bar (pin) goes through and write it down or memorize it; 3. Undo the buckle/clasp; 4. Measure the width of strap in place where the buckle/clasp was fitted and write it down or memorize it; 5. Measure the length of the strap (both parts together) and write it down or memorize it. Now you have everything you need for strap replacement. Visit any shop selling leather straps or even find it on the internet. You will find thousands of different colours, patterns and leather variations. The choice is yours. Just one thing to remember: The strap you are buying must match all the measurements you took of your original strap. This is not difficult to match, as the watch straps usually are made to global standards. When you have your new strap delivered, just fit it to your watch and undo the buckle/clasp that came with it. Fit your old, original buckle/clasp on to the new strap and you are done. Most watch manufacturers impress, engrave or laser engrave their logos on buckles/clasps, not on the leather straps itself. So, when you fit the original buckle/clasp on brand new strap of different make, it becomes the original strap of the watch you own. And nobody knows that the strap is, for example, from Hong Kong, but watch is from Switzerland (except you, of course} as they look together as one nicely designed piece and the buckle/clasp works as the proof of identity. In case if your watch has some unusually shaped fixing for the strap, this shape can be easily cut in to the strap by modellers scalpel. At the very end I just want to remind to all readers: Watch straps sold under watch brand names are 2-10 times more expensive. In fact - they are not produced by watch manufacturers themselves, but in Italy, Germany, China and Hong Kong and then sent to watch manufacturers. Just because these straps were fitted to the watches and the buckles or clasps were added to them, these straps automatically becomes their brand straps and cost a lot, lot more. Hope it helps to save your hard earned money.
on Jan 10, 2010 | Watches
Received Skagen watch Order No: W256417 today. Mesh Band is too long for me. I do not understand step 2 of instructions Ray Reeves
Ajusting the Clasp - Skagen signature mesh bands are easily adjustable in just three simple steps:
LIFT - SHIFT - PRESS Lift the slotted clasp, Shift the adjustable buckle to the desired position (make sure the clasp is set in one of the indentations on teh back of the band), Press the slotted clasp closed.
Aug 18, 2010 | Skagen Watches
Unclear as to how you adjust the rubber band strap
  1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
  2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
  3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 16, 2010 | Tissot T Race Case Stainlesssteel carbon...
I need to know how to put on a Haurex watch using it's intricate band
pull the small loop on the end of the metal clasp. place the other strap through the loop and snap closed. fold one end of the clasp shut then the other.
Aug 07, 2010 | Haurex Italy San Marco Chronograph Watch...
Clasp broken and needs repaired
The most trustworthy place to send your watch is the makers service center or take it to a makers authorized dealer.
To find the address, go to "" and click on your area and then on "wittnauer" and then on either "service center" or "dealer locator".
Mar 02, 2010 | Watches
The folding deployment clasp on the bracelet/strap for my Tag 1000 series ladies watch has broken. Might a replacement clasp from any of the current tag models fit?
The newer straps on TAG are generally wider than the professional series and the cost of a new genuine TAG heuer clasp or bracelet may easily exceed the costof buying an entire watch of that series used.
I recommend searching for an after-market strap/ buckle usuing your case back numbers as the search criteria.
Oct 17, 2009 | Watches
Mens Versace leather strap. How do I adjust the band ? The watch has a cream face, square in shape, chronograph with a brown elather strap. Clip requires adjusting and cant work out how to adjust..
Well i am going to roll the dice and assume you have one of the ez clasps but if I am wrong you can send the model number and we will figure it out.
To adjust the ez clasp pull up on the front of the clasp loop while pushing down on the band. Rather than the traditional buckle and prong set up, the prong here is underneath the clasp loop.
Hope this helps. Thanks!
Sep 20, 2009 | Versace Watches
$ 4.00 for skagen will send you a new clasp. but if the clasp is just open you can close it by applying pressure to the the hinged piece if its stubborn move it back and forth a little until it hits a grove.
Nov 06, 2008 | Skagen 358SSSD Wristwatch
Citizen Eco-Drive mens watch
Hi if it is anything like the other eco watches ---------
just under the clasp that lifts up you will find a little button, it is about 2mm long and there is one on either side, push these in with your thumb and index finger and it should release the clasp.
When you close it up,you will feel it `pop` back home again.
Dec 26, 2007 | Citizen Eco-Drive BL006056H Wrist Watch
Casio AWS90D-2AV Wrist Watch Logo
383 people viewed this question
Top Casio Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
