When I installed my Windows XP CD the sound card(sound driver) is being deleted and When I on or shut down my computer, I cant hear the log on sound, as well as music cannot be played video is being played bu no sound is working...Please can you solve this problem?
Hi.. Of course the sound is not working you need to install the sound driver. Load you CD motherboard driver in your CD room and install. It composed all the components of your motherboard the sound and the video display. After you install all the components it requires you to restart to take effect. Thanks for using fixya. Good luck! Regards PCmania
Did you just reinstall (or install for the first time) Windows? If so, did you install all the appropriate drivers for the system (such as sound, networking, graphics, etc.)?
first of all uninstall the sound drivers you have installed.go to support.dell.com select drivers model ,type confirm, this will take you to the driver download page.select your version of windows, if you know the sound card by name select it download or run it .
Good luck
if you have bought an xp disk the chances are there will be no sound driver installed, if you have the recovery disk (or sometimes called system disk) the sound drivers should be on there, or safer still go to www.dell.com support and look for the sound drivers there, good luck
yes it is problem *********** board built in sound card audio ic i mean realtalk or soundmax digital please you buy a pci sound card such as creative or otherbrand,creative is a best sound card other brand assembling it and install driver
Thanks
Tareq
Wiz
www.fixya.com
I have an HP model t3529 and want to use a 2Gb or 4Gb readyboost capable SD card. Will my card...
(More)
I have an HP model t3529 and want to use a 2Gb or 4Gb readyboost capable SD card. Will my card reader support SDHC? **** M
when i switch on my zenith desktop by pressing the CPU button, green light is glowing, cd drive...
(More)
when i switch on my zenith desktop by pressing the CPU button, green light is glowing, cd drive light is glowing but the red light of CPU is not glowing. Finallym the computer is not getting switched on. please help as this is happening very ofter
With power on, a "power button lockout" will appear on monitor and monitor will turn black...
(More)
With power on, a "power button lockout" will appear on monitor and monitor will turn black and will lose all research I have accomplished?????????
