Question about Canon PowerShot A70 Digital Camera
Battery My camera drains the battery in two minutes. what can i do
    Problem Solver:
  • 8 Answers
See whether the batteries are new
Posted on Dec 05, 2007
Nikon Coolpix keep resetting Time and Date and menu settings.
I am listing this tip for the Nikon Coolpix 995, but the tip is valid for all Nikon Coolpix models.
The Nikon cool pix settings are saved into an internal memory.
The internal memory is maintained by an internal rechargeable battery, that is recharged from the main Li-Ion battery.
If you leave your Nikon overnight with no main battery, or if the Li-Ion batteries have drained, then the internal battery will also drain , resetting the clock and other settings, saved on the internal memory. The camera may even drain in about 6 hours depending on the camera, normally it takes at least 12 hrs to drain the clock battery.
If the internal battery is resetting immediately, after you set the clock, or just after few minutes, then the clock battery must be replaced.
The camera must be disassembled completely to replace the battery located on one of the two main internal boards.
Nikon says that the clock battery loosing charge is normal. I quote what they say on the publication titled " The Nikon Guide to digital photography with Coolpix"
"Backup battery of the clock
The clock-calendar is powered by a separate rechargeable battery, which is charged as necessary when the main battery is installed. If the camera has been stored with the main battery removed for a long period of time, the clock may need to be reset. Once the main battery has been reinserted, the clock battery will recharge in several hours, during which time the main battery should be left in the camera."
Original file: Download here
If the clock does not work at all, and is resetting immediately, even though the Li-Ion batteries are fully charged, then the best thing to do is calling Nikon, at the number listed on the owners manual, telling them that you did not do any improper use of the camera, and trying to get the fault repaired as factory defect. That is not always possible, and the decision depends on Nikon customer service.
See also: Nikon | Contacts
on Feb 05, 2010 | Nikon Coolpix 995 Digital Camera
My minolta maxxium 50 works fine but is draining the batteries after a few minutes, what could be making this happen?
What battery does it use? The problem could be your rechargeable battery is dying. If it is the case you need to replace your battery.
Oct 01, 2009 | Konica Minolta Maxxum 50 QD with 28-100...
Sony DSC-S70, battery not charging to a full charge
That battery is not good.if the battery have warranty please give back and get new one. after that the problem continues, The charging control ic of the camera may be damaged
Sep 21, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
Rapid battery drain, also with new battery
u have a shorted power board.i had same problem when mine got wet. likley not repairable.
Aug 22, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
DSC-W12: the batteries last only a few minutes before they're drained. Camera draining batteries very quickly.
If its a Lithium ion battery(similar to a mobile phone battery) then open battery compartment, clean battery contact points and try again after recharging the battery. If the camera uses AA batteries look for the current ratings on the side of the battery, generally digicams need batteries with more than 1200 mAh (I use a 2000 mAh for my Canon SX110 IS digicam). This current rating may vary for different manufacturers.
Jul 25, 2009 | Sony Cyber-Shot DSC-W12 Digital Camera
Every time I put new batteries in (rechargable batteries or not) the camera will only last to take 1 or 2 photos then say the battery is flat. why is this and is it repairable?
If the camera has been exposed to moisture there may be condensation still inside the camera; this causes a short and cause undue drain on the battery. Will also eventually damage the camera. remove the battery and leave the battery cover off .Place the camera in a warm place for a couple of days, or aim a blow dryer into the battery compartment for a few minutes.
If that doesn't help,then it's probably a defect in the camera circuitry and it's not worth repairing with the low price of digital cameras these days.
Jul 23, 2009 | HP Photosmart M447 Digital Camera
Batteries Dying Quickly
Change the internal rechargeable battery.
Dec 01, 2007 | Konica Minolta DiMAGE Z5 Digital Camera
Batteries draining
I am having the same problem, if you get an answer please let me know.
Oct 25, 2006 | Fuji FinePix S5500 Digital Camera
Canon PowerShot A70 Digital Camera Logo
41 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
