LG 50PG30 HDTV Plasma TV
Problem for LG 50PG30 HDTV Plasma TV
No picture on the screen it is totally black and i do get sound.
By virginiamndy on Aug 27, 2009
the TV has a totally black screen, it shows no pictures. It does have sound
Best Solution
posted on Aug 27, 2009
Very Helpful)
pegasus_four
Rank: Guru  LG Televisions & Videos  Expert
Rating: 90%, 149 votes
There will be a problem with the backlights not being switched on, you would need to check if you are getting the supply voltage to the Inverter board (24V). If not check the power supply, if it is present then check if the backlights are functioning with a backlight tester, if these are ok check the capacitors on the inverter board. If the backlights are faulty then a replacement screen would be required.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for LG 50PG30 HDTV Plasma TV
Questions and Unsolved Problems for LG 50PG30 HDTV Plasma TV
Do you recommend LG 50PG30 HDTV Plasma TV?
Answer
Answer
My Pioneer 435Fde media reciever has 1 HDMI port. How do I connect 2 HD devices to it, eg. my sky... (More)
Answer
why does it take two hours to get a picture on my tv you get the sound byt no picture when it comes... (More)
Answer
LG 50 P56ZD PLASMA I HAVE SOUND BUT NO PICTURE
Answer
I have a LG 50PG40 Plasma TV how do I switch off TV, rather than having on standby.
Answer
i want to run it through a reciever but i only get sound on the hd channels but not the normal... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG 50PG30 HDTV Plasma TV:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
