Question about Dynex DX-WOM20 Mouse
Mouse trouble my mouse doesnt work unless i restore my computer. when i restart my computer.....my mouse doesnt work....please help
  • Anonymous Apr 18, 2008
    my mouse dose not work
  • sunny1873 Jul 12, 2008
    After 8 minutes not using my Dynex mouse it goes to sleep, which is normal. Then I press every switch on the mouse, according to instructions on http://www.dynexproducts.com/skins/skin_... and nothing happens. I turn off my laptop and start from scratch: the receiver and the mouse do not connect.
    Can you help?
  • 66 Answers
To fix this problem, first uninstall your mouse in your device manager. After this, use the mouse's install CD to reinstall the driver. If you do not have a CD, or it does not require a CD, windows may already have the driver pre loaded and can take care of it. If not, you can goto the mouse manufacturers web site and download the driver from there.
Posted on May 15, 2008
Having major usb issue
Do a restore, to back before you installed it, you just want to do the restore point before the install then you start fresh and then make sure under your device settings that you have more than one usb port active, designate under the default programs that the auto play is on, you get it, easy.
Jan 28, 2014 | Computers & Internet
While taking recovery,1st disk remain incomplete and show an error to restart.my laptop is just 1 month old,i am unable to detect the problem,please furnish me with a successful solutions,i am too wor
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 26, 2013 | Sony VAIO Computers & Internet
My computer want start and every times I starts it it say error and please restart
Feb 04, 2013 | Computers & Internet
Gateayw gt4010 does not boot up,fan starts auto when power turned on. No post beeps,no keyboard or mouse detection.
check leads from motherboard to hard drive IDE/SATA make sure connections are secure and dust free make sure the keyboard and mouse lead's or usb device is securely seated want to make sure
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
if you need more help with this or if i have misunderstood your problem post a reply
hope this helps you
Aug 31, 2011 | Gateway GT4010 (RBGT4010) PC Desktop
All of a sudden I lost control of my mouse pad. The indicater will move around but it will not respond. I did add a wireless mouse and it still does the same Dell computer
Try restarting your computer, and while its booting up, tap f8..
then choose last known good configuration..
If that doesnt work for you, try using the keyboard to navigate to system restore..
The first step is pressing the windows key on the keyboard, and then by using the tab key and enter and the up and down arrows, navigate to
all programs, accessories, system tools, system restore..
Then perform a system restore to a time before this issue started
Oct 30, 2009 | Computers & Internet
I have the same problem with my Compaq. Its frozen on the logo
hi there..
turn of your computer..
unplug all the cables...
press and hold down the power key which is on your cpu for atleast 5 - 10 secs..
after that ..please connect the power cable.. mouse.. key board. monitor and your internet cable..
and then restart your computer..
when you restart your computer keep tapping the f1 key (i hope this is for bios)..
restore to default over there.. press enter to save.. once done this would automatically reboot..
this should fix this problem...
please post your answers.. or comments...
Aug 20, 2009 | Compaq Computers & Internet
Compac presario mouse stuck when on desktop but not on log in screen. little box on task bar with red through box
Get an external usb mouse, once you have it plugged in restart the computer. Then go into the device manager and uninstall your old mouse, unplug the usb mouse, then restart. That should fix your problem. Let me know if you need more details.
Feb 19, 2009 | Acer Aspire 3680 Laptop
Mouse not working in HP 4800 series computer...yes it is old
the very first thing what u can do is that try in the safe mode and if work in safe mode then do the system restore to an earlier time when mouse was working fine and still if it doesnt work in the safe mode also then uninstall and reinstall the synaptic driver and restart ur computer it should work or what u can try is that try it with the other mouse and if the other mouse work on the computer then replace ur present mouse and if that doesnt work then reinstall the operating system and try and still if it doesnt work then replace the motherboard...that is the last solution for ur issue pls provide the feed back
Dec 26, 2008 | Warrior 797146022002
Locked Keyboard?
I don't know if this would help however I had a problem with my keyboard earlier today. What I did was restore my computer to an earlier date. In my case I restore it to yesterday date and it worked.
Nov 07, 2007 | Microsoft Wireless Optical Desktop Comfort...
Dynex DX-WOM20 Mouse Logo
164 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Mike
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
