Question about LG WM1814CW Front Load Washer
Error code de
How do I resolve this issue?
  • mandem Dec 07, 2007
    I have a top load machine , WT-H755A which is giving me error code 'dE' which says the door is open. The door isn't open.
    Any clues?
  • 489 Answers
You have a problem with the door latch assembly and may need to be replaced.
Posted on Apr 28, 2008
Sc 536 error code
Ol? tudo bem! o erro funcional (SC 536) trata-se de um cooler ou do sensor de temperatura que parou de funcionar levando o sistema a parar de funcionar por medida de seguran?a, infelizmente trata-se de um daqueles problemas que s? a autorizada resolve.
Jan 14, 2013 | Ricoh Toner for Aficio 1060, 1075, 2051,...
What does the dE error code mean
dE = door error. Most likely a door latch issue.
DE = drain error. Plugged filter or bad pump motor.
Apr 18, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Clear code for engine light
The code clearing happens via two things> first, resolve the issue causing the error code. The code will come back if you do not resolve the issue. you can clear the codes by using a code reader, but it woudl likely reappear. Fix the issue causing the error code.
Remember, the code is a clue, not always the issue.
Mar 02, 2011 | 2004 Mitsubishi Endeavor
The washing machine operates normally until it reaches the "spin" cycle, it stops, beeps and the code "dE" appears. Thank you.
Hi
Thanks for using FixYa. DE is a door open error, you’ll have to check the door if it’s properly closed. Also check loose electrical connections at the door switch and PWB assembly. If everything appears to be fine then it is the door switch assembly that should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 29, 2010 | Washing Machines
LG WM2277HW dE error code coming up at end of cycle. Door is locked, cannot open or reset to get clothes out.
Hi
Thanks
Rylee
Aug 28, 2010 | LG WM-2277HW Front Load Washer
How to reset the de message
Press the START/PAUSE button and the displayed error code will disappear and the machine will go into pause status.
Power will be turned off automatically and the error code will blink if the error is not resolved within 20 seconds.
It is a door open error and usually caused by a faulty door switch assembly or broken door latch hook.
Make sure the door is firmly closed and avoid overloading the machine. Clothing may come between the door and cause the error.
Feel free to inform me if the error is not resolved. I will guide you how to check the door switch assembly and how to replace it.
Jan 02, 2010 | LG WM-2277HW Front Load Washer
LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Dec 03, 2008 | LG WM-2277HW Front Load Washer
Getting error 0xc18a0206
Aquí es el contenido de la charla, espero que te ayuda también! Christina es la persona de soporte técnico.
Cristina: Vamos a realizar algunos pasos para aislar el problema y encontrar una solución para ello.
Christina: Por favor siga los siguientes pasos y que me haga saber el mensaje que se mostrará en la impresora.
Christina: A. - Mantenga pulsado el "*" tecla.
B. - Presione la tecla "#" y suelte ambas teclas.
La pantalla debe decir "Intro Especial clave Combo"
C. - Presione y suelte en la secuencia de "1", "2" y "3" botones.
CustomerName: ok
CustomerName: pantalla dice "apoyar" R0631M
Christina: Fine.
Christina: 2. Oprima y suelte el botón de flecha derecha hasta que la pantalla dice "Menú de configuración del sistema".
Christina: 3. Oprima y suelte el botón "Aceptar".
Christina: 4. La pantalla debe decir "estado de error de hardware". Si no existe ya, tecla de flecha a "estado de error de hardware",
Christina: 5. Oprima y suelte el botón "Aceptar".
Christina: 6. La pantalla debe decir "estado de error de hardware: Despejado. Pulse OK para borrar ".
CustomerName: yup
Christina: 7. Oprima y suelte el botón "Aceptar". Mensaje a los cambios "estado de error de hardware Resueltos. Pulse Cancelar para continuar ".
CustomerName: ok
Christina: 8. Pulse y suelte el botón "Cancelar" tantas veces como sea necesario, de modo que, o bien el "Bienvenido a Photosmart Express" aparece la pantalla, o, el "fallo del sistema de tinta" aparece la pantalla. POR FAVOR, NO intente imprimir en esta etapa.
CustomerName: ok
Christina: 9. Utilizando el botón de encendido, apague la unidad y desenchufe el cable de alimentación de la parte posterior de la impresora y la pared.
CustomerName: hacer
Christina: Fine.
Christina: 10. Espere 30 segundos para obtener el poder de vertido y, a continuación, enchufe el cable en la toma de corriente y, a continuación, en la parte posterior de la impresora
CustomerName: hacer
Christina: 11. Encender la unidad. La impresora puede mostrar mensaje "BOTóN PARA PODER UTILIZAR LA IMPRESORA SHUTDOWN" seguido de "Pulse OK para continuar". Pulse Aceptar. La impresora comenzará la "TEMNE UNA TINTA proceso de inicialización". Permitir que este proceso para completar y no interrumpir. Una vez que el proceso de inicialización se ha completado, la impresora imprimirá una página de diagnóstico.
CustomerName: hizo una buncha ruido, y no imprimir una página de diagnóstico
Christina: Bueno.
Christina: ¿Es todavía el mensaje de error que se muestra en la impresora?
CustomerName: No
Christina: Bueno.
CustomerName: debo intentar imprimir algo?
Cristina: Vamos a imprimir una página de prueba libre, para comprobar la funcionalidad de la impresora.
Christina: Pulse sobre el menú de configuración "todo en uno" luego desplazarse utilizando la tecla de flecha y seleccione la opción Imprimir a continuación, seleccione Informe de Autoevaluación Informe de ensayo.
Oct 22, 2008 | HP Photosmart C5180 All-In-One InkJet...
LG WM1814CW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
