Question about Sony DVP-NS575P DVD Player
Player won't play any disks only says CANNOT LOAD DISK
Any disk I try in my Sony DVP-NS305 dvd player doesn't play, its any dvd and I tryed my disk cleaner and it doesn't play that either. It is driving me mad what do i do? I tried loading a few different types of CDs and DVDs. The documentation keeps pointing to a change in weather or humidity and let the thing dry up ..., which I'm trying now.
  • 1 more comment
  • Anonymous Mar 09, 2008
    We have had the same problem. Just about to throw it away after taking it apart, cleaning it, you name it. Then I thought turn it upside down (keep it upside down when playing dvd) and now it works.
  • Anonymous Mar 15, 2008
  • princessmiss Jun 16, 2008
    my dvd player wont play any disks it won't even play a lens cleaner disk. the progressive light is on. you can hear the disk spinning but it won't play
    Sergeant:
    Champion:
  • 231 Answers
Open unit and blow off carefully on laser eye with dust can if not there is a good chance your laser and or spindle motor in laser assembly is bad .Easy to change out .part # 8-820-237-06 (comes with spindel motor) at www.sony.com in parts/acess section ..If you do decide to change yourself make sure you unsolder small dot of solder on laser before install ..This is shipped soldered for static reasons..goodluck
Posted on Dec 05, 2007
    President:
  • 4,402 Answers
You can try this
http://www.llamma.com/xbox/Repairs/cleaning_your_dvd_drive.htm
its for xbox but all cdrom drives are simulate
Hey... i had the same prob but that guy ahead of my solved it
turn it upside and play it
its working now... thanks guys.
Posted on Jul 04, 2008
Sony DVP-cx860 Disks won't feed from the carousel into the reader.
The thickness of DVDs and CDs often vary and the surfaces are too slick. Roughening the outer edge(s) of one or both side(s) of the disk was an immediate fix for the loading problem.
Jan 14, 2012 | Sony DVP-CX860 Multi-disc DVD Player
I have a sony dvd player model dvp-ns305 i live in rhodes greece family send me films on formatted discs but my player says can not play this disc? can you give me advice or solution
If it plays other bought discs, then maybe your DVD player has been configured not to play pirated discs or the films weren't copied well.
Nov 25, 2010 | Sony DVP-NS305 DVD Player
My DVP-NS305 was playing all DVD's (multi-region) in colour but now only shows them in B&W. How do I change it back?
you can change colour setting in dvd setup to auto.after that colour come.when change setting power off dvd play then i will work fine.
Oct 17, 2010 | Sony DVP-NS305 DVD Player
My sony dvp-ns305 Dvd player will only play in Black and white.
first try to check the setting if its in ntsc or pal same with your television
Oct 09, 2010 | Sony DVP-NS305 DVD Player
A disk is stuck in the tray of my sony DVP-NS305 player. The disk tray will not respond to either the hand piece or the button on the player itself. The word "Locked" comes up on the display. How...
Unplug power cord, and whenb you plug power back and restart the DVD, keep pressing repeatedly the eject button on the unit.
Do this a couple of times.
If it does not work you will need to take apart the unit to take out the disk. In this case consider calling a qualified technician if you are not sure about how to do it.
Oct 04, 2008 | Televison & Video
http://forum.videohelp.com/topic350059.html
I think I found these adjustments! There are two tiny surface-mount potentiometers (could be capacitors also) sitting in the small circuit on laser assembly.
this is exactly response I would like to hear - an expert opinion!
What I did with help of 1mm-wide screwdriver:
1) There were two surface-mount potentiometers marked with C1 and D. I tried first D. Turned it clock- and counterclockwise by about 45 degrees.
2) After each turn I opened and closed tray to force the player read DVD disc.
3) It did not help, "NO DISC", then I tried the same with C1, and again, no luck.
4) Finally, I came back to D and turned it by about 180 degrees in one direction. IT WORKED!!!
Moreover, seem that now player reads content of the DVD discs faster then before. Probably manufacturer did not really adjust it properly and upon the time something has degraded, so it failed eventually.
Some Home dvd players may not have any adjustment abilities, but you would find such things not too far away from the lense, if they don't exist, get a new unit.
Jun 22, 2008 | Philips Magnavox DVD/VCR Dual Player
DVP-NS50P will not load DVD
the lense could be only dirty, try cleaning it first. i suggest do a manual cleaning if you can. open the top cover of the unit, remove the disk retainer and you will find the lense somewhere in the middle. use a cotton bud, use a little of alcohol, dampen a little only and wipe the lense in circular motion. then use new dry bud to dry it.
May 04, 2008 | Sony DVP-NS50P DVD Player
Is it multi region already?
not u would have to set the code to 0 all sum do sum dont usally need a unversal region free player out of box to do it
Feb 03, 2008 | Sony DVP-NS305 DVD Player
change the way you connect the dvd player to your tv
Jun 22, 2007 | Sony DVP-NS305 DVD Player
Sony DVP-NS575P DVD Player Logo
226 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
