Question about Konica Minolta PagePro 1350W Laser Printer
PagePro 1350W When I go to print, a error message appears on the bottom bar of the computer that said "Konica Problem."  When I clicked on this, a box opened; I clicked on "Proceed," then it would print, but another item would appear at the bottom saying "Konica Minolta Paper problem which indicated 2 possibilities: 1) I wasn't using the right toner cartridge or 2) I need a new toner cartridge.  Neither of these is correct.  Hard to believe that the toner cartridge bought 6-8 weeks ago is already empty! Also, about 1 week ago, the error light began flashing even though the printer would print.  "Cancel" doesn't clear it; turning the printer off doesn't help either.  It seems a toner cartridge should last longer than 6-8 weeks.
Time has nothing to do with how long a toner cartridge will last. What is the page count on the cartridge?
Don't expect too much from it if it is the original cartridge that came with the printer as they have a very short fill.
Posted on Jan 12, 2008
5 Suggested Answers
  • 3 Answers
SOURCE: konica minolta 1350w status display comes on at start up
Open c:\windows\system32
find a file called MSTMON_Q.EXE
right click and rename the file to anything with a file extension .exe, I named it MSTMON.EXE
Create a shortcut to this new file in case you need it in the future and put the shortcut on your desktop
also, write the original name of the file down or put it on notepad, in case you want to change it back.
restart windows
Posted on Apr 16, 2009
SOURCE: KONICA MINOLTA PagePro 1350W
You have to connect it to exactly the same USB port. For every time you connected to a different port compared with the last one, a new copy will be installed.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Posted on Aug 23, 2009
SOURCE: Konica Minolta PagePro 1350W Laser Printer won't print anymore
You have to be sure that you are connecting the printer in exact the same USB port. If you are connecting to a different port and not to the one from was disconnected, the Windows is installing another copy of your printer. Check this, I believe this is the solution to your problem.
freetek
  • 5568 Answers
SOURCE: konica minolta pagepro 1350w fatal print spooler
A 'print spooler' is a range of memory either internal to the printer (sometimes called 'buffer memory') or set aside from the RAM in your system. A fatal error normally means the material you tried to print has been lost and must be sent to the printer again. If the error continues to show up, you may have bad printer memory or perhaps the driver software in your system has gotten stepped on by the operating system and needs to be reinstalled. Windows loves trashing files to keep life exciting.
This problem is not related to the drum or toner cartridge.
Posted on Oct 10, 2009
Konica minolta pagepro 1350w not feeding full page but get stuck at half page.
check the size of the document make sure the print drivers and the printer are correct and matching you might also need to replace the fuser unit or the transfer roller and or image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 16, 2014 | Konica Minolta PagePro 1350W Laser Printer
My Konica Minolta pagepro1400w suddenly stopped printing there're no error messages and all jobs go into Que and but it will not print.printer is correctly connected.any suggestions will be...
if there is any other printer installed on your computer but not in use then delete it, remove the drivers from your computer and re-install KM Page pro 1400w.
Jun 14, 2010 | Konica Minolta PagePro 1350W Laser Printer
Konica minolta page pro with windows 7
I looked at the manufacturer's web-site:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=1350W
and you are correct -- there are drivers for 2000/XP, and for 95/98, but nothing for Vista nor Windows 7.
Find an old computer running Windows 2000 or XP, and connect the printer to it, and "share" the printer across your home-network.
Apr 07, 2010 | Konica Minolta PagePro 1350W Laser Printer
Pagepro 1350w prints with streaks on left side
Hello sir; Not thing you can use forever if lifetime is out you need to change otherwise the streak line not go away.
May 13, 2009 | Konica Minolta PagePro 1350W Laser Printer
Go to printer faxes check and it might change the default setting and it might default Microsoft Office Document Image Writer. When you print make sure that you are printing to a right printer you can select the printer of your choice by clicking the down arrow. If you select the right printer and it did not print I suggest that uninstall the print driver to the control panel, add or remove and install a new printer driver. make sure set as a default.
Jan 27, 2009 | Konica Minolta PagePro 1350W Laser Printer
Only allows "print to file" will not allow printer to print.
you can go to printers and change the port to the virtual usb printer port....from the file port
Mar 30, 2008 | Konica Minolta PagePro 1350W Laser Printer
Will only let me print to file
Click on konica minolta properties, go to ports then check the correct port. Uncheck the print to file box
Mar 27, 2008 | Konica Minolta PagePro 1350W Laser Printer
Pagepro 1350w install/print problem, vista document stuck in queue,error
Go to control panel, printers, right click the pagepro and select properties. Click the ports tab and make sure that the port is set to a USB port. This did it for me.
Mar 17, 2008 | Konica Minolta PagePro 1350W Laser Printer
Error light
You have installed a refilled cartridge without changing the chip on the bottom of the cartridge. Your error light will flash and also upon starting your computer, you will probably get an error screen saying the bi-directional connection is disabled. The printer should still work, but will be slow because it recycles between each page. My error light has been flashing for some time, but when I send a document to the printer, the error light stops flashing and the printer prints. After the print job is done, the error light resumes flashing. The only real solution is to replace the chip on the toner cartridge with a new one.
Dec 18, 2007 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer Logo
266 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
