FixYa.com
Tags:
Microwave Ovens
Generic problem for all Microwave Ovens
OLD Kenmore Microwave Oven (by 2 users)
posted by BbRrYyAaNn on Dec 05, 2007
It just stopped working and before I write it off, I was wondering if there is anything I can check. I hate to get rid of it because it is BIG and POWERFUL (1400W). I already tried the fusebox and a different outlet.
Comment by BbRrYyAaNn, posted on Dec 08, 2007
That was very informational...Thank you. I guess we have opted to buy a new microwave, esp. since I saw that it was purchased in 1982!! My parents always took excellent care of their appliances. It was running for about 3 minutes and somewhere along the line, it just went dead. I heard it stop without the audible tone so I knew something was wrong. I have to imagine that newer models are more efficient anyway.
Regards, BRYAN
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Dec 05, 2007
thermador double wall oven-microwave stopped working
Best Solution
FixYa! (100)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2734 votes
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
Comment by MicrowaveSvc, posted on Dec 08, 2007
While the info above may apply, you might get better results if you post this in the Thermador area, under your model number if available, and please include your model number in the post.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 18, 2008
Not Rated (0)
jdcj
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i have an old but perfectly good operating kenmore under cabinet micro model 228.7374 purchased 12/24/86 from sears. it has feature five on the door,the keypad has preheat, bake time,toast, oven temp, combo time, broil time, micro time, & the #'s 1thru 10 , micro power, clear, start, stop, time , solid state. the kenmore book that came w/ it pictures does not match the micro keypad. today's menu's also call for med heat. can someone tell me how to get med & lo heat settings? thanks
Comment by jdcj, posted on May 19, 2008
help please
This Problem Also Relates To: GE JE620 650 Watts Microwave Oven GE XL1800 1100 Watts Microwave Oven GE Advantium SCA1000H 900 Watts Convection / Microwave Oven GE JE1460 1150 Watts Microwave Oven GE JES1238 1100 Watts Microwave Oven GE JES1358 1200 Watts Microwave Oven GE JES636WK 700 Watts Microwave Oven
Can you Help with these Microwave Ovens problems?
Microwave Ovens
whirlpool micrwave oven...
whirlpool micrwave oven... Answer This...
Microwave Ovens
oven did not get hot.
turntable turns, light on... Answer This...
Microwave Ovens
Frigidaire microwave is...
Frigidaire microwave is... Answer This...
KitchenAid KHHS179LSS 1100 Watts Convection /...
Error 7
my microwave shuts off... Answer This...
Emerson MW8168B 1100 Watts Microwave Oven
turntable inoperable?
Turntable inoperable? Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
