Question about Amana NDE2335AY Electric Dryer
Amana Dryer NDE2335AYW
My dryer won't start at all, timer motor isn't running. We have traced some electrical and everything is good so far. The motor overload protector is okay. What should I look for next?
  • 2 more comments
  • AmyInCleburn Jan 13, 2008
    Same problem here. Dried a load, went to change out, pushed the button, and NOTHING! This thing wasn't cheap and I really thought it would last me more than 2 years.
  • Rick Atkinson Jan 18, 2009
    Dryer will not start. Power supply is good. Have checked door switch Thermal fuse and I can find nothing wrong but it still will not start. When you hold the start button in you can hear the timer motor.
  • Amber English Apr 12, 2009
    Simply stopped working - worked this morning - not now. / not very old
    Simply stopped running - worked this morning - not now - only a couple years old.
Found my problem. The 3 prong unit on the cord connecting at the dryer. One of them was melted. Glad my house is still standing.
Posted on Jan 13, 2008
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 11, 2013 | Amana Dryers
Dryer will not come on at all. working fine on last load
check house fuse/circuit breaker
door switch
if an electric dryer the thermal fuse as they are often wired into the motor run circuit
check for power to the motor in start and run circuit, if present motors spent.
if not present trace back to timer and verify timer is sending power, if not timers spent.
more likely circuit breaker, door switch or thermal fuse if electric dryer..
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | Kenmore 64902 Electric Dryer
Won't spin or start
Sounds like the screen/sock combo got the tub in a bind and the drum belt broke.
If you want to pursue replacing the belt, let me know.
Apr 30, 2009 | Amana LGA10 Dryer
Loud noise from dryer
Good Afternoon,
If a toothbrush went into the dryer it would have to remain in the drum. There are no outlets large enough for a toothbrush to fit through. Can you tell where the noise is coming from? Also, check the drum good, the toothbrush could be hiding behind one of the ears in the drum and you probably can't see it. Try running your hand behind the ears inside the drum, it just might be there! I hope this will help you and thank you for using FixYa!
Mar 22, 2009 | Amana NDE2335AY Electric Dryer
Amana Model NDE2335AYW Needs a Jump push to get started drying. Have so far been doing this by lifting the top and pushing the drum
That means that your motor is going . I'm not sure how much your willing to put into it but that tends to be kind of expensive. good luck
Jan 11, 2009 | Amana NDE2335AY Electric Dryer
Installing a drum belt on an Amana NDE2335AYW
call me if you'd like and i'll walk you through it Jim 417-926-0106
Dec 20, 2008 | Amana NDE2335AY Electric Dryer
Amana dryer ple330RAW
look for something stuck in the impeller (blower fan) that would cause the motor to hum and not run. If nothing is stuck your motor may be shot.
Aug 15, 2007 | Amana DLE330RAW Electric Dryer
Kenmore Dryer Timer does not advance
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Apr 14, 2007 | Kenmore 64902 Electric Dryer
Amana NDE2335AY Electric Dryer Logo
523 people viewed this question
Top Amana Dryers Experts
Sal De
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Amana Dryer Expert? Answer questions, earn points and help others
