Question about Brother MFC 240C All-In-One InkJet Printer
Printing only in grey
First bought the printer and it printed normally in black. Very clear. Also did great color prints. After I replaced my ink with the same kind of ink from Brother, it started printing everything in grey. I have a IMac G5.....please help
  • 832 Answers
Can you do simple copies in b/w without probs?
If yes, you might have checked the greyscale at the printer settings.
If no, do a quality test print (pressing ink etc.). If you cant read the instructions in black, the ph or circuit board is defectiv.
Posted on Dec 05, 2007
5300 kodak printer black ink dont work
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 25, 2013 | Kodak EASYSHARE 5500 All-In-One InkJet...
Hp officejet 4255 black colour print not very clear
Select print in grey scales only in printer properties while shooting the print command, printer is using color cartridge instead of mono cartridge..
Jan 11, 2012 | HP OfficeJet 4255 All-In-One InkJet...
When using the 520 cartridge it prints grey. after cleaning it prints black for only so long then reverts to grey
you are either just about out of black ink in the 520 or the cart is not flowing properly for some reason. The "grey" print would be the mix of colour inks that these printers lay under the black to make the print "blacker".
If cleaning etc doesn't help, replace the black cartridge.
good luck with it
Dec 03, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
I have a kodak ESP-3 all in one printer that has a new black, and new color ink cartridge, and the printer does not print any colors. only prints black, grey, and a litte bit of greenish tint.
Inkjet printers do not like being left unused.
The color print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Epson rx700, the black prints grey
replace another black cartridge the cartridge is factory defect
Nov 03, 2009 | Epson Stylus Photo RX700 All-In-One InkJet...
Can i print without color catridges
you do need both cartridges in and with ink or the printer will not print to prevent damage to the print heads from running dry. The printer normally uses a small amount of coloured ink to "tone" blacks but if you leave it set to Black only it won't do this and in the future you should only have to replace the black cartridge.
May 21, 2009 | Canon PIXMA iP1600 Printer
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
HP2605dn will not print
yes, it is normal
the newer printer has senser for ink cartridge. printer will not print if any of the ink cartridge is empty.
therefore, you need to replace the emply ink cartridge in order to print.
Jan 14, 2009 | HP Color LaserJet 2600n Printer
Prints grey not black
I solved this problem but probably not what the printer manufacturer would recommend! The reason you are just getting grey is that the black ink cartridge is either empty or dried out from non use and only the color cartridge is working. I had the same problem after being away for 5 months. I put the printer cartridge in a bowl of warm water to disolve the dried out ink on the print pad. I dried off the cartridge with a soft cloth and then it worked perfectly.
Feb 25, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Hp officejet 5610 how to select black ink printing only
Start, Printers and faxes, Right-click your printer - Properties, Printing preferences, Advanced, Print in grayscale - Black only...
Nov 05, 2007 | HP Officejet 5610 All-In-One InkJet...
Brother MFC 240C All-In-One InkJet Printer Logo
113 people viewed this question
James Cagle
James Cagle
Jim Keysor
