You can download the required manual from:
http://support.casio.com/manualfile.php?rgn=1&cid=001005004
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
SOURCE: Casio Exilim Ex-S880
I have had this issue on several Casio camera the lens comes out fine and then goes right back in some times it just gives you two beeps and nothing else. the problem is with the lens its focus motor is out of ajustment. According to Casio this is not covered under any type of warrenty coverage and that ****.but hehe sometimes you can take it back to places like bustbuy and if you have your receipt they will sometime swap it out. But lets say they don't. well you sometime can get a replacement lens for it off ebay for pretty cheap. This is only if you are sure that you can fix the camera. If you choose to have it fixed make sure you shop around there is a huge diffrence between shop to shop.
SOURCE: Casio Exilim EX-S880 I put
if you try pushing the battery in further it might turn on, if that doesn't work just get a new battery, but make sure to take it out when you aren't using it or this will happen again.
SOURCE: Casio Exilim EX-S880 how to unlock card
hello, check your card for a clip and see if its in lock position. set it to unlock.
also check if your card is compatible for you cam.
SOURCE: My Casio Exilim EX-S880 wont turn on. Battery is
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
SOURCE: My Casio Exilim EX-S880 wont charge.
I had this exact same problem. Here's a solution. I had to do it about 7 times and others on Amazon said they had to do it about 20 times. But it does work! My light is a solid red as we speak! Good luck!
ylu1 writes:
what i did was...
hope this helps.
