Question about SanDisk Sansa e260 MP3 Player
Sansa e260 problems : Music files freezes the sansa and restarts it.
I've had my sansa for a bit less than two months and it seems like I've had some problems with it. All of the sudden, while listening to it and scrolling down for songs, the music didn't play any sound and after a while it froze up. I tried to shut it down and restart it but it just stayed frozen, but later it was slowly changing into a blank white screen. I couldn't do anything with it, so I just let it run out of batteries.
When I got home, I plugged it into my computer and checked the files. It seems that the videos are fine, as well as my pictures, but when I checked on the folder for music, the sansa's screen froze for a bit then restarted. I tried it again, plugged it in and rechecked the folders, still the same thing. Then I unplugged my sansa and checked the files in there. Both video and photos were fine, as well as the sound for the videos. But when I reached the music section and selected a song, it frozed, and restarted. What sould I do?
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
Can load music on my sansa e260
Try converting the file to mp3 format, then paste into your music section of your Sansa e260
Mar 12, 2010 | SanDisk Sansa e260 MP3 Player
When on click on my sansa e260 in Rhapsody I see
Try the following method to see what is on your Sansa e260
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
If you want to delete some or all of the files do the following:
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 29, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 restart
because you have a problem in the music, you just have to format it than it will come back
Feb 07, 2008 | SanDisk Sansa e260 MP3 Player
Why does this happen to my converter/e260? (pic)
the sansa media converter is only used for videos and pictures.
for song you go to my computer and u will see that it says sansa e260 you click on it then it will have files for music vieos pictures and recoding click on music and drag ur music on to it.
Jan 11, 2008 | SanDisk Sansa e200 MP3 Player
IT wont turn on
tyr holding both the power button and the play button for 20seconds at the sametime
Dec 28, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260 4 gb mp3 player
You could reinstall the firmware (what makes the sansa work). Its pretty easy to do, no need of downloading/installig, its already all in the sansa. You just need a computer How do I restore the firmware Firstly, place the e260 in restore mode. To do this, follow these steps 1. Push the Hold button on top of the e260 to the right. 2. Hold in the record button 3. Press and release the Menu button 4. The device will now go into Restore Mode. If you have not already connected the USB cable to your PC, it will direct you to do so. 5. The root directory of the device will open up on the PC screen. Now drag and drop the two files Firmware into into the e260 root directory. You will find a copy of the two firmware files zipped up elsewhere on these forums 6. Push the Hold button on the e260 back to the left 7. Unplug the USB cable from the PC. The e260 will now reboot, writing the new firmware images to the correct location. 8. This process will have wiped all your music files. You will now need to re-synch.
Jun 28, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
63 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
