Question about Sony STR-DB940 Receiver
Rear speakers not working
When doing a test tone, all speakers work except the 2 rear speakers.
Help!
  • 1 more comment
  • park2080 Dec 07, 2007
    does S.F. initialize blink or just stay on for a moment then go away?
  • park2080 Dec 08, 2007
    s.f. initializer did not fix the problem. rear speakers still not working!!!!
    Frustrated!
  • lmiatio Jan 07, 2009
    I'm having a similar problem except that it's only wit the right rear speaker channel. The left one works fine.
    Sergeant:
    Champion:
  • 231 Answers
  • Try this on your rceiver to see if it corrects your problem .If not make sure rear speakers are activated and properly connected
  • Sound Field Clear Mode
    The preset sound field is cleared when this mode is activated. Use
    this mode before returning the product to clients upon completion
    of repair.
    Procedure:
    1. While depressing the [MODE +] button, press the power `/1
    button to turn on the main power. The message S.F Initialize
    appears and initialization is performed.
Posted on Dec 05, 2007
  • jackgerhart Jan 05, 2011
    I have the same problem - is there a fuse inside that I can replace? SF Initialize did nothing. Test tones won't play through rear channels
The system WAS working fine. After I moved I installed the system again now the front speakers are not working. I'm sure it's not the cable or the speakers (if i connect in example: the left rear...
The system would have hung up. Please remove the power and leave the set aside for over 6 hours so that the processor will reset if there was any error that have crept into while it was powered . Also remove and reset all the speakers, if possible with an individual test on each- use a 1.5 V AA cell-.
The amplifer can also be reset if there is a note in your manual.
Oct 05, 2011 | JVC TH-A10 System
Dear sir,my surround amp rear speakers are not working.model is kr-v5580.other functions are OK..Pl's help
1st try a test tone to the rear speakers. If you can not get a test tone check the connections again.. once you get a test tone, use the "mode" button on your remote to cycle through the surround modes and make sure you are in a surround mode rather than a stereo mode.
Sep 29, 2010 | Kenwood KR-V5580
Rear speakers no longer function
Have you run the test tones in surround or ProLogic ??
Feb 03, 2010 | Pioneer Audio Players & Recorders
No sound out of Front Left/Right Speakers on 5:1 setup
i have the same problem with my sony receiver. seems like the fronts and sub have no output after sitting idle for about one and a half years. center and rears are ok. any help folks?
Feb 08, 2009 | Pioneer VSX-05
No sound from rear speakers during test tone usng Sony STR-DE475
I had this problem last night.
To solve it, you can reset the amp by:
1) Put the receiver on stand-by
2) Hold down "MODE" button and press on button
3) "S.F. CLR" appears in the display and surround is back on.
Good luck
Dr Gardner
Jan 21, 2009 | Sony STR-DE475 Receiver
Samsung ht-z310 home cinema no sound rear speakers
I seen the same thing when I first opened mine except my "center" speaker wan't working. It had to do with the "Mode" it was in. The Mode button at the botoom of the remote changes the speaker configuration.
There is also an option in the setup that allows you to turn on/off speakers for the system, all of mine were either Present or Small which enables them to work.
Jun 29, 2008 | Samsung HT-X50 System
Cant connect rear speakers
Hey there Subaquakid, the nature of surround systems is to identify separate extra channels of information and send them to the right address, being the selected speaker. In order for the rear speakers to work they need to be sent a signal. The media which you are using may not have the rear channel encoded. therefore the rear speakers have nothing to announce. Please ensure your source cd has the suround feature encoded. Hope this helps. Good Luck!
Jan 28, 2008 | Dell WL6000 Computer Speakers
Dialogue vs. background music and sound
The on-screen menu appears only when the selected source is DVD or VCD on the DVD/VCD/CD player and the disc is in the slot and NOT PLAYING. On the remote control ONLY: 1. Press CHOICE (it should work now) LANGUAGE menu appears. 2 Press Cursor to move to the menu you want? which is AUDIO Selected item changes its color to green. THEN: 1. Display EXPERT SPEAKER SETTING menu. 2. Press Cursor to select ?TEST TONE,? then press ENTER. ?TEST TONE? changes its color to green and test tone comes out of in the following sequence?left front speaker, center speaker, right front speaker, right rear speaker, and left rear speaker. ? Test tone is output only when the tray loaded with a DVD is selected, but not playing. 3. Press Cursor to move to ?C.SPK? LEVEL? or ?R.SPK?LEVEL,? then press ENTER. 4. Press Cursor to adjust the output level, then press ENTER. ? You can adjust the output level from ??6 dB? to ?+6 dB.? 5. Repeat steps 3 and 4 to adjust the other speaker output level. 6. Press Cursor to select ?TEST TONE,? then press ENTER. Test tone stops. 7. When finished, press Cursor to move to ?EXIT,? then press ENTER. EXPERT SPEAKER SETTING menu disappears. I hope this helps you, please let us know. Best regards, nightdiver
Jun 13, 2006 | JVC MX-DVA9 Shelf System
Sony STR-DB940 Receiver Logo
417 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
