Question about Watches
New fossil watch
I just got a brand new fossil watch and i can not get the time to start. it is just a plain fossil with day and date. when the watch came from amazon.com is it possible that the battery has some kind of protector on it so it didnt die ? and if there is some kind of a protector over the battery how do i get the cover off?
  • 1 more comment
  • crysgarza Dec 27, 2007
    How do I change the battery out?
  • Anonymous Mar 27, 2014
    fossil store replaced battery, still losing time. puchased 1/30/14
  • Anonymous Mar 29, 2014
    can you tel me what type of battery goes to fossil bq 9279 watch. when I open the watch I saw the small and big place for battery, but I didn't shore whitch kind of battery goes in the watch. small hole is under the big place. Can yuo help me?
    Thanks
  • 14 Answers
It is not likely that there is a protective cover over the battery itself, if there is anything on it to prevent use while not owned it is a little pc of plastic holding the stem out. It is sad to say but there is no way to tell how long the watch had the current battery in it before you received it. It is common to get a new watch and have the battery die shortly after or be already dead. Go to a local jewelry store to have replaced, make sure they are able to test the old one FIRST, if the battery is dead, allow them to replace it, if the battery is fine, return the watch to Amazon.
Posted on Dec 05, 2007
How to change the date on a fossil stella watch
For the single dial (winding crown). Pull out one click and this will change the date, pull out another click to change the time and keep winding forward or backward to get change the day and 24hour clock.
Feb 02, 2012 | Fossil Stella Topring Watch
I Have a fossil 10 atm watch & the date doesn't change automatically so i change it manually but then half way thought the day it changes the date
Your watch is 12 hours out of step.
The date changes every second time the hour hand passes 12 O'clock.
Your watches' second pass is at midday instead of midnight, so to make it operate correctly, you need to wind it on 12 hours. The date will then change at midnight.
Jul 13, 2011 | Fossil Watches
How to set or restart the fossil automatic ME 1030? Because the problem now is when the time turn at 12 at midnight, the date din turn..
sometimes during time set, the hands are set to change date at day time.
check it your date turns during 12 noon, if yes move the hands clockwise until you set your time and date on sync.
say you want to set your watch date:10th and time:10:15am
adjust your date at 9th
then move your hands clockwise until the date turns to 10th at the 12 thats the 12 midnight.
then continue moving your hands clockwise until you reach 10:15am
Dec 14, 2010 | Fossil MultiFunction Automatic ME1030...
My me1020 came without instructions and i do not know how to set the date, min nor theday please help
Actually there is no instruction manual for ME1020 available on Fossil website except for how to replace the battery. When you try to match ME1020 model with the available diagrams, there is no match (4 eyes). To set the time, pull the crown out to the second position. Now set the min/hour hands. Date hand is linked to it so keep rotating the crown till the date is set is set correctly. Now remaining is the day setting. Notice that the day changes every 24 hour mark on the 24 Hour sub-dial, so cross this mark to change the day. Go reverse & again cross the 24 hour mark to get the next day. Repeat this till you get the correct day setting. Now your day is also set along with date & time!
Feb 14, 2010 | Fossil ME1020 watch
Changing the date on a fossil watch- how do you do it?
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
Dec 12, 2009 | Fossil Watches
George watch
From the clock mode, hold the Lap/Rest button until the "seconds" counter flashes. Use the Start/Stop button to advance the time, use Mode to switch between hours, seconds, date, etc.
Sep 11, 2009 | Fossil Watches
Setting the day on my watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
Mar 14, 2009 | Fossil BQ9183 Wrist Watch
Fossil JR9589
(I'm dutch, so I'll try in my best englisch)
I don't know if you still have the problem, but what you should do is te following:
* pull out the knob (2 times) and turn anti-clockwise to change the time
* keep doing until it's 24.00 (midnight) and you day change's to the UK (!) day.
* push back the knob (1 time) and change the day to the FRANCE (!) day by turning anti-clockwise
* pull out the knob again and turn anti-clockwise to change the time until 03:00 (midnight)
* you see the then change the day back to the UK day
So, every night at 00:00 the day changes to the FRANCE notation and at 03:00 it then changes to the UK notation, so you can enjoy this setting during the day.
Good Luck.
Also owner of JR9589 watch.
May 26, 2008 | Watches
Setting the month,day, and date.
Alot of times on watches you can click on the stem one time and you can change the hour. Click on the stem and you can change the minute, date, and month.
Jan 04, 2008 | Watches
Watches Logo
574 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
