Question about Panasonic CQ-VD7001U Car DVD Player
Radio works cd/dvd does not.
Installed cqvd7001u and when I turn the radio on the subs and amp are on and working fine. When I switch mode to cd/dvd there's no power going to amp and subs. The screen shows tracks playing but no audio. dvd no pic or audio. please help.
    Problem Solver:
  • 7 Answers
What do you have your remote wire for your amplifier connected to?
Posted on Dec 21, 2007
When i have the stereo on radio my amp/subs work fine, but as soon as i switch the mode to USB ( built in ipod connector) it cuts out the power to the amp/subs. It only works on tuner mode (radio) why?
use the blue/white wire (amplifier remote turn on) instead of the blue wire (power antenna remote turn on) to turn your amp on. the power antenna wire shuts off when leaving tuner mode.
Mar 02, 2011 | Sony DSX-S100 Car CD/ MP3 Player
The tuner works fine, all the speakers play including my sub. When I put in a cd, only my sub makes sound, and when I go to the ipod no sound comes out. However When I go to the zone control and select the...
are you using more than one amplifier? it sounds like you may be using the blue wire to turn one amp and and the blue/white to turn the other one on. use the blue/white only. the blue wire is antenna remote and turns off when not in tuner mode.
Jan 09, 2011 | Kenwood DDX516 Car Video Player
I just installed a sub and it only is working for
there should be two blue wires. one solid blue and one with a white stripe. if i remember the solid should be antenna remote and the blue with white stripe is the amp remote turn on. if you are using the power antenna,it will turn off the amp when not in radio mode.
Mar 08, 2010 | Sony CDX-GT420IP CD Player
I have an amp powering two subs but only work with the radio and not when its in aux mode or cd mode. do i need some other conection
I am not familiar with your head unit but I know some radios can control audio options for each source. My unit has adjustments for bass treble fade sub out etc in each source like radio, dvd, cd usb etc. I would check this first. For example, my radio can have the bass set to zero while the dvd can have the bass set to 5. If this is the case for your stereo, the sub out for the different sources can still be set to off.
Feb 22, 2010 | Alpine CDA-9851 CD Player
Jensen uv8 sub works with radio an dvd but not with cd
quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
May 19, 2009 | Jensen VM9510 Car DVD Player
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 19, 2009 | Sony XPlod CD Player w/MP3 Playback...
My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Jun 24, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Amp and subs cut out when I insert a cd in my radio
You have the amp connected to the blue wire on the radio instead of the blue one with the white stripe. The blue one is the power antenna wire so when you switch to cd, it would close a power antenna. If you dont have a blue /white wire, you can hook it to the red 12v wire. Good Luck
Mar 07, 2008 | Car Audio & Video
Amps wont stay on
try to look at the connection on the back of the cd player and make sure that the amp power wire is connected to the power wire on the wire harness on the back of the cd player and that should work but i only need one amp for a pair of 6by9s and subs try to bridge the speakers all to one amp that should cause it to sta on while in cd mode hope that helps
Dec 26, 2007 | Kenwood KDC-MP435U CD Player
Panasonic CQ-VD7001U Car DVD Player Logo
191 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
