Question about SanDisk Sansa e250 MP3 Player
My Sansa e250 wont turn on
Nothing, blank screen, won't charge either, help!
  • boeman Dec 06, 2007
    1. only blue light come on then off
    2. held down on menu 20 sec. nothing
    3. move hold on top back and forth, nothing
    4. un=hook from PC nothing
  • elise15 Dec 06, 2007
    My player's battery was to low to opperate, so I tryed to charge it on the computer. It doesn't work, only a blank screen appears.
    Problem Solver:
  • 5 Answers
Http://sansae200.blogspot.com/
Posted on Dec 07, 2007
2 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sansa E250 Black screen lighted wheel, wont do nothing else.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
Theres a blank screen after charging mp3 it wont turn off
Press the power and the Play (>||) button together for 20 seconds to reset the unit
Feb 28, 2010 | SanDisk Sansa Fuze MP3 Player
My mp3 will charge but when unplugged doesn't work
Make sure the hold/lock is not engaged
Reset the player
Run the Sansa Recovery Tool from Sandisk's website
Nov 24, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
hold the power button for a SLOW 20 sec, then power up with NO PROBLEM!
Aug 31, 2008 | SanDisk Sansa e250 MP3 Player
My sansa wont turn off its just a blank screen
ive had that problem b4 i dont no if uve already fixed it or not, but all you do is hold the power button fer 15 seconds and itll shut off
Mar 13, 2008 | SanDisk Sansa e250 MP3 Player
It wont turn on !!!
My Sansa won't turn, and its been giving me a lot of difficulties since I bought it. It just turned off and like died. It won't turn back on. HELP!!!
Jan 22, 2008 | SanDisk Sansa e250 MP3 Player
My sansa wont shut off
its called pushing the power button
Jan 07, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 PLEASE HELP!
The battery has come disconnected from the charging contacts in the back.
Remove the 4 screws, remove the battery from the back and re-insert it.
Best of Luck.
Oct 26, 2007 | SanDisk Sansa e250 MP3 Player
MY SANSA E250 JUST DOESNT START.......
try holding the menu button until it turns off then leave it off for around 30 minutes then try to power it back up. If it still wont turn on perform recovery mode and upgrade the firmwar eof the player if havent done so.
Aug 27, 2007 | SanDisk Sansa e250 MP3 Player
My sansa e250 wont turn on.
i suggest to call sandisk support for this one. And how did you recieve the cracked screen? Because if it physically damage then it would void the warranty of the player. Their number is 1-866-7263475
Jun 22, 2007 | SanDisk Sansa e250 MP3 Player
I need help with my sansa e250 mp3 player
Hi. Seems like your player may be encountering some corruption. Try this and see if it would help: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Let me know if this helped :)
Apr 21, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
166 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
