Question about Teac P-A688 Turntable
Teac turntable belt came off.. help!
Hi! The belt on my teac turntable came off and I was wondering if you have a schematic to let me know how to put the belt back on,,, Thanks!
  • PondWaters May 21, 2008
    I had the same problem with my belt coming off, unfortunately I need a more detailed description. Pictures would be helpful if possible.
  • maureenmarsh Jul 30, 2008
    belt came off
    Novelist:
    Champion:
  • 382 Answers
Through the 2 holes on the platter, lift the platter up. Take the belt, flip the platter over, and stretch it around the center ring. Flip the platter back over and turn to so one of the holes is over the spinning motor. With your finger or with a blackstick, stretch it back onto the motor head.
Also check the belt for wear....that should do it.
Keep me posted.
Posted on Dec 16, 2007
Need a diagram of the belt configuration
Check out YouTube there are some standard videos on belt replacement that might apply to your model.
Oct 14, 2015 | Teac P-A688 Turntable
Need a new belt
Measure the old belt, make certain you know how it fits before removing. You need the diameter and width in MM. You don't need to be spot on with these! Put the results with the words "Turntable belt XXmm by XXmm" into Google.
Aug 13, 2013 | Teac P-A688 Turntable
I have a Teac LP200 and the turntable will no longer turn when I lift and move the arm over. Is there a belt to replace? How does one access it?
your unit has "The efficient belt-drive system provides accurate play and control" and normally the belt lasts for long time ..i.e at least 5 years..
If you sure that it is belt ,you need to take the turntable disc (should be a security pin in the middle ) than you can access underneath of disc or some models needs to access from bottom of the turntable ,inside the receiver..
just in case ,if you need detailed user manual in pdf format pls visit he URL below..
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
User Guide for Teac LP-U200 View Table Of ContentsĀ»
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jun 25, 2011 | Teac LPU200 Turntable
Hi, the belt on our Teac Turntable has come off while moving to new home. Can I get manual that shows how to put it back on?
If you open the top lid of your turntable, you will see a black rubber disc that sits on the pladder, it should come off revealing the metal pladder, you should see holes that will show your belt and the turntable motor when pladder is rotated. In order to put the belt back on you must remove the pladder, but before you do check to see if there is a C clip holding it down, after removing the clip the pladder should come off, put the belt on the inner rim of the pladder, now slowly work the pladder on the spindle make sure one of the pladder holes allows you to see the motor, put a small blunt object between the belt and the inner pladder and use it to stretch the belt to slip over motor then push the pladder down and rotate it making sure the belt is turning with the motor, next replace the rubber disc and finally the C clip if it is present.
Dec 21, 2010 | Teac P-A688 Turntable
I NEED A REPLACEMENT TURNTABLE BELT FOR TEAC JC 50 STEREO
Just measure the diameter of the old one and it's width. Then put these measurements (in mm please) into Google and and the words "TURNTABLE BELT " and you should find one. Belts are not maker specific.
Jun 24, 2010 | Teac Audio Players & Recorders
Turntable belt is off.
Under the felt of the turning platter section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
May 16, 2010 | Teac GF-600 Turntable
Belt on teac turntable came loose, I don't know how to put back
its simple the belt goes around the platter and the motor spindle thats it!
Apr 11, 2009 | Teac P-988 Turntable
Turntable won't turn
Hi!
Without any other information (and assuming you've checked to make sure there is power to the turntable and that it is turned on), the likely culprit is the belt drive of your turntable. Most, but not all, turntables have a "belt" that looks like a big rubber band on the underside of the turntable that connects the turntable itself to the drive motor. If the band has slipped out of place, stretched too far from age or usage, or broken, the turntable won't turn. To find out if this is your problem, gently lift the "platter" straight up (it should easily slide back into place) and visually see if the "rubber band" is in place. If it is stretched too far or broken, a new one should be availble form Teac or your local electronics supplier. If, by chance, you have a direct-drive turntable (unlikely), the problem will probably need professional work.
Good luck and please let me know if this helps!
Bob
Oct 09, 2008 | Teac Audio Players & Recorders
Belt
On the bottom of the silver platter, there is a round lip.put the belt around that. Then put the platter back on the table and turn the wheel until you get to the motor, which is the gold pin on the left, and put the belt over that.
Jan 13, 2008 | Teac P-988 Turntable
Teac P-A688 Turntable Logo
1,149 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
