SanDisk 2Gb Micro SD Memory Card Problems
I have a 2Gb Micro SD card, well it says that it is, but when I check the memory on it under my computer and propeties it said that it only has 965 Mb when it should have at least 1800Mb on it. I tried reformatting it, taking it to the store i got it from (Which he was able to get the 2Gb to show up) but then I started having other problems, it wouldnt let me put files on it, so then it started saying I was using 965 Mb when there wasnt any files on it, so I reformatted it again, now it says there's only 965Mb on it. How do I get it so that the other Gb shows up?
  • 6 more comments
  • Anonymous Mar 08, 2008
    ooooh my GOD!!!!I HAVE SPENT ONE DAY WITH THAT!!!!!!Exactly the same problem!!!!I use a MAC and an external card reader for my MicroSD and at the disk utility,it shows me that i have only 965 MB but underneath,it shows me i have 1,9GB...Although my card has 2GB, i cannot transfer data more than 965 MB, and i get a message that memory is full....!!The card has no problem,as it is read from 2 other mobile phones as a 1,9 GB total storage card....So it MUST BE THE CARD READER....I'll check it out tomorrow,as i am going to buy one....!!!!
  • xcuteguy04x Jun 02, 2008
    Ok, so your answer sucked.. sorry. I have a 2GB Sandisk MicroSD Memory card, and I'm using it in a 4GB max card reader.. my cell phone. My cell phone is an LG Rumor. The memory card is supposed to be able to hold a little over 400 songs, however, it'll only hold 127. It says I still have 1400416KB of free space out of a total of 1985024KB, and I've only used 584608KB so far. I was told that the songs had to be in wma format, but I have no idea how to do that because when i tried to convert my songs from mp3 to wma it didn't work. I also would like to know where online I can find a good file format converter for free. I hope you can help.
  • mojotro Jun 16, 2008
    Same problem. Bad card or is there a fix?
  • Anonymous Sep 08, 2008
    I have this same problem but my card reader is on my desktop, is there a way to maybe adjust card reader settings without having to replace it?
  • kiburadera Sep 28, 2008
    i've a 4GB micro SD sandisk and whenever i put it into my Blitz Verizon phone n open it on my computer, it tells me that its storage capacity is 18.6MB and now it's now even showin up at all...how can i fix this?
  • Anonymous Nov 10, 2008
    I have a 2GB Sandisk Micro SD card. I use it for my DS. When the guy at the store put in games, it said 32 games max. Now, when I want to transfer some games from my Mac, I can only put 14. then I decided to remove EVERYTHING, and it says i only have 9.9MB left. Help?
  • Anonymous Mar 05, 2009
    my computer cant read my 2gb micro sd now, but was fine before. how to i solve this?
  • bretche zamora Oct 07, 2011
    i have a 2gb micro sd,but when i insert into the cellphone the memory card is error. What is the problem of my memory card?
Hi everyone,
I did not mean to put myself up as an authority on SD memory cards but, through a number of forum sites the problems described are all of a similar nature and I am receiving a lot of email regarding problems with these cards. I am posting this on all forum sites in the hope this will make things a little clearer.
Firstly one must understand exactly how a memory card works. The SD 1.0 documentation produces a string code which all computers will recognise. The card stores blocks of binary information in 'clusters'.
In the original SD format it stores 4096 clusters with up to 512 blocks, each block containing 512 bytes of information. This gave a card capacity of 4096 x 512 x 512 = 1 Gigabyte. These cards typically came pre-formatted to the FAT-16 file system with the MBR partition scheme. This meant that any computer or host type device would recognise them through a card reader .
Now for the rub.....With the advent of high capacity cards the string code went to SD 2.0 documentation, the block capacity was increased from 512 bytes to 1024 and 2048 giving a capacity of 4096 x 512 x 2048 = 32 Gigabytes, and these cards can only be formatted to the FAT32 file system.
For this reason an SD card reader will not recognise the data stream from a SDHC card. The situation is being further complicated because there is now an XC (extended capacity) card on the market which has a capacity of 2 terabytes (2048 Gigabytes) but this is at present being limited to 64 gigabytes by the SD 2.0 documentation.
What all this means is.....you don't use a 5 ton crane to move a 10 ton rock.....doesn't happen. If you wish to use an SDHC card (the card will be branded SDHC) you must have an SDHC card reader. The reader will access the information so the computer can handle it. This is why a lot of people complain the card will work in their phone but not their computer.....the phone has an inbuilt HC reader which the computer can access through USB .
The first thing you must do when you purchase your SDHC card and SDHC card reader is to format the card to the FAT32 file system otherwise you will not get the rated capacity out of the card......this is also a common complaint. Also, under no circumstance do a defragmentation on the card. All the clusters are equally accessable so there is no need and you will only wear the card out quicker.....remember these cards do have a finite life and the more you re-write them the sooner they will wear out.
Sorry....I don't want to sound like a 'know-all' but I have been using these cards since they were released onto the market and, like you, I have had to learn through trial and error.
I have a JVC card camcorder and I use 32Gb and 16Gb cards in this camera. My computer is something of a dynosaur by todays standards being a pentium 4, 3gb processor, 512 mb RAM and a 7,200rpm 120Gb hard drive but, I have no problems accessing and using these cards, no matter what the make, but as I have said, I have made it my business to find out what makes these cards tick.
Hope this is of use.....and potentially cuts back on my email traffic.......Rob... and greetings from Aussie land.
Posted on Sep 13, 2009
  • 140 Answers
Your problem seems to be your card reader, you are trying to read a 2gb card in a 1gb max card header.
Posted on Dec 05, 2007
YEAH YEAH YEAHH!!!I found it....It was what dynomaster said....I BOUGHT A NEW CARD READER AND EVERYTHING IS FINE!!!!!Its not a oroblem of the card,but of the card reader,as it cannot recognise data more than 1GB,possibly because it was an old model!!!
Posted on Mar 08, 2008
How can i rapeir micro sd memory card in computer/card redar?
The are several reasons for SD, SDHC, or microSD "card locked", "card error", "no memory card", or "format card" problems. This link outlines troubleshooting steps for these problems. Or you may view the following video summary of these troubleshooting steps:
May 13, 2012 | SanDisk 2GB microSD Memory Card
I forget password of sandisk 2gb micro sd memory card
you can unlock your sd card by formatting*.
formatting memory card will delete all datas
formatting method*
use a softtwaer phone for formatting.. (example nokia 6120c, 5800etc )
insert your sd card into the softwaer phone.. select SETTINGS > DATA MGR > MEMORY > OPTIONS > FORMAT MEMORY CARD
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
My pc dont read micro sd scandisk 2gb, I need drivers
buy a cardreader.put the micro sd memory card in the cardreader's slot.connect cardreader to the to the computer and the computer can read your memory card.
May 31, 2011 | SanDisk 2GB microSD Memory Card
My2gb sandisk micro sd card always ask to format the card but the computer/mobile unable to format it please help
most likey it is a faulty card . or a cheap counterfeit . i had same problems and only a new card was the solution
Aug 02, 2010 | SanDisk 2GB microSD Memory Card
If i connect my memory card 2gb sandisk to computer he cant read it
2gb micro sd card is locked and i miss the password please solve my problem
Dec 15, 2009 | SanDisk 2GB microSD Memory Card
The SD m2 2gb Micro does not work on my phone
the card shows sign of a rom ic being lost its firmware
Sep 05, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
How do I use the SanDisk adaptor and the SanDisk 2GB microSD
The micro card (the smaller one) can be used alone in a port that accepts (microSD ports)such as those on a Sansa c240, c250, e250 etc.
If you have a regular SD slot (larger than microSD) then you plug the micro card in the adapter and plug the whole into a regular SD slot.
Plug the card in your computer and copy paste the files. Or plug the micro card in an MP3 player that accepts it and use you music transfert software.
You only have one card (the micro SD one), which you can use in two possible slots.
Hope it helps.
May 19, 2009 | SanDisk 2GB microSD Memory Card
2gb micro sd From Sandisk printer won't read.
From what info I have gathered is that my card reader on my printer is old and will not read that big of card. so off to the computer store to buy a new card reader.
Jan 19, 2009 | SanDisk 2GB microSD Memory Card
Micro SD 2 GB just stopped working
The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
Jul 02, 2008 | SanDisk 2GB microSD Memory Card
Computers & Internet Logo
3,444 people viewed this question
Alun Cox
David Payne
David Payne
