Cameras Logo
Posted on Aug 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic Camera lz2 not show pic before take it just black
I opened my cam Panasonic Lumix Digital Camera lz2 after that when i reinstalled every part in there every systems work good but its no take pic its show black its make flash and zoom and snape shot but no pic show in its screen to take pic so if itake pic its show black
KHATRI CAMERA
Level 2:
  • Expert 67 Answers
  • Posted on Aug 27, 2009
KHATRI CAMERA
Expert
Level 2:
Answers
67
Questions
Helped
23688
Points
150
Hi ,there is problem in CCD of your camera,plz check fitting of ccd well, and if you get same problem then sorry to say but may be you must change CCD
Is there a reset for the lumix dmc lz2
my camera works but it has a black screen fore a pick but show the menu and stuff
While i was trying to take a pic, i got this "WRITE ERROR".... I switched off the camera and switched it back on. everything was fine but there was this BLACK pic... now I cant delete,edit,or do...
INSERT THE CARD IN A CARD READER CONNECT TO A SYSTEM AND DELETE THE FILE WITHOUT OPENING IT. BACK UP YOUR PICS. AND FORMAT THE CARD.NOW YOU ARE TO USE IT IN THE CAMERA.
REGARDS.
PLZ. DON'T FORGET TO RATE
Dropped lumix but now everytime I switch it on its tells me to open the lens cover even when it is open.
It shows a problem with the motorized lens mechanism.I will prefer unscrewing the camera only if you are such an expert because there are very fine mechanics inside the Panasonic Lumix DMC-LZ2 which could be easily damaged if mishandled.Please take it to the nearest authorized service center.
I know this is not the solution you were expecting but I won't allow a much bigger damage due to mishandling.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
3helpful
2answers
I need to download free software for Lumix DMC-F3 camera.
Here are panasonic's available downloads for your device.
GOOD LUCK AND PLEASE RATE THIS POST!!!
May 09, 2011 • Cameras
Transfer pics
Use a card reader to download to a folder you create on your desktop. From there, you can use any program to view your pics.
I don't know how to get the pictures I took off of my panosonic DMC-LZ2 I have it plugged in but my computer doesn't recognize it..
switch off your digi cam !!!! connect the digi cam via dta cable to the PC !!! now switch on the cam !!! keep your digi cam in display picture mode !!! now u can use your digi cam like a pen drive
Problem with Panasonic Lumix DMC-LZ2 camera
hello baylie101, this message shows when the camera picks up a lens fault, if the camera has taken a knock or drop something could have went faulty in the lens. camera should be looked at by a qualified technician.
The camera itself.
shutter not openining. ccd flex not plugged in correct or it is faulty. main pcb fault. first turn the camera on then check if the shutter opens.
Panasonic dmc-fx100
The manual can be found in the link below.
DMC-LZ2 Instruction Manual
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
