Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
The Motor is running but will not fill with water. I checked the water supply and drained the water out but it still will not fill with water.
  • R1CO Dec 07, 2007
    I did add the water but the dishwasher did not advance no the next step. Time for a new one. Thanks for your advice.
  • chatak Jul 02, 2008
    hi, my dishwasher is no working. dont hav any clue what n where the problem could be . i switched it on and could hear the motor sound but not filling th water but after some could c the dishes becoming warm without being washed n rinsed.
I have a gibson energy saver disheasher and the water will not fill. motor is working
Posted on Dec 07, 2008
Assuming I have all this straight, I have the same model with a plastic interior. There is a little upside down cup looking device up front on the far left. Apparently if you tap on it, it helps. Ok, I banged on it a bit and went beyond the tap GE recommends. It just worked with mine, thank GOD! It's the day before Thanksgiving, need one that works.
Posted on Nov 26, 2008
  • 883 Answers
Symptoms:
>Motor is running
>not fill with water
Causes:
>machine "thinks" it is already filled with water because motor is running
Sol'n:
>manually fill with water to proper level and close door...re-fill as needed...until machine commences next phase
...if no machine shows no new actions after above has fulfilled, then the main controller circuit is somehow bad
...if machine does advance to next step, then you have a faulty signal from water level switch...could be bad switch or wiring to it.
Posted on Dec 05, 2007
5 Suggested Answers
  • 20 Answers
SOURCE: I installed according to guide, but dishwasher
you state the water supply is on.
Have you loosened the compression nut at the dishwasher ell to see if you have pressure to the water inlet to the dishwasher?
Remember the dishwasher will always run a little to make sure any residual water from the last load is out of the bottom, so you could here the pump run a minute or so with no water coming in.
If you have Pressure to the water inlet and no water coming in regardless of the cycle/ timer position, it is most likely a bad electrical connection or switch at the water pressure actuator which is were the compression drop ell connects to the dishwasher.
This is the one and only actuator to let the water in to the dishwasher.
So it could be one of or combination of five things: no pressure to actuator,the electrical connection the actuator is loose or bad, the actual actuator is bad or timer timer is bad.
Most likely it is a loose electrical connection or lack of pressure to the actuator
Posted on Apr 05, 2009
heatman101
  • 43501 Answers
SOURCE: The dishwasher fills with water,
DishwasherRepair Problem Detergent Cup does not Open
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Oct 27, 2010
  • 25 Answers
SOURCE: Dishwasher will not fill with water
Bosch D/w Have a float switchin the base pan of the unit you can access by removing the toe kick, if there is water in this base pan it turns the drain pump on and will not do anything else. So until the water is removed either vacume it out , or let it evaporate or however the unit will only drain
Posted on Jan 25, 2008
heatman101
  • 43501 Answers
SOURCE: Beko DE3762FW dishwasher starts but will not
Here is a tip that will hjelp you with your problem...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on Aug 14, 2010
Water run in tub when washer is off and leaks all over, this is a built in whirlpool dishwasher
If it's clean water the fill valve is bad turn water supplies off see if leak stops. Is it still leaked with water supply turned off check drain hose could be to low causing drain water to back fill into tub
Mar 30, 2016 | Washing Machines
Unit acts like it has received water then continues to cycle as if it hasn't, no water is pumped???
Symptom Check
Click on underlined items for further information Washer does not work and makes no noise Washer does not work but it does make noise No water is entering the wash tub
- or no hot water
- or no cold water The water fills the wash tub too slowly The tub does not fill with enough water
  • Test the water level switch
  • Check that the drain hose is positioned roughly as high as the top of the inner tub
The water overflows the wash tub Water drains out during the wash or rinse cycle
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Wrong temperature of water is used
  • Water supply hoses may be reversed
  • Hot or cold water supply valve may be turned off
  • Water supply hose may be kinked
  • Check water inlet valve
Water drains out while it is filling
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the cam bar
Water drips into the wash tub when the washer is off Water does not drain out of the wash tub Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Agitator does not move Agitator movement is weak or moves in only one direction
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
Drum does not spin
  • Test the lid switch
  • Test the centrifugal switch
  • Test the motor
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
Spin:
  • Test the motor
Cycle does not advance
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
Burning or electrical smell
  • Unplug the washer
  • Locate the source of the odor then read the instructions in the related section
Foul or stale odor coming from washer or clothes
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Goes out of balance too often Clothing is damaged
  • Inspect agitator for cracks or rough spots
  • Inspect for rust spots
Jul 11, 2015 | Washing Machines
Calypso will not advance past wash cycle. I have a Calypso GVW9959K washer that displays no error codes and will run all functions in test mode. Problem is - it will run forever in the wash mode (clock...
If the machine is filling and washing but not advancing then the timer mechanism is not fuctioning. There is no codes so all other parts must be working, likke the pressure switch. You might test the door or lid switch this can sometimes hang these up. to test simply jump across the switch with a jumper wire. Basically
  • I am supplying the service manual for this machine. Please be careful when attempting any repair and always make sure the machine is unplugged before starting any repair. This manual include service guides for testing components as well if your capable of these tests. The link will lead you to the manual. These manuals are not easy to come by due to the fact they are meant for service personell who make a living on these so it is inclusive and should help you in you issue.
  • https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
  • May 13, 2011 | Washing Machines
    Washer will fill spin and drain but will not wash
    • first check the motor power supply whether it is fine or not
    • next check the motor coil whether it is working or not
    • If both are ok the motor power supply and coil is fine means you are suppose to check the pressure starter since it is giving the signal to the wash motor to run
    • kindly change the pressure starter to solve your problem
    May 14, 2010 | Washing Machines
    The motor turns on but no water is entering the dishwasher to start the wash cycle.
    Hello there
    Here is the most common troubleshooting tips
    Dishwasher does not fill with water or it drains while filling
    • Check that the water supply is turned on. The valve may be located under the sink.
    • Check the door latch
    • Test the door switch
    • Inspect the float assembly
    • Inspect the fill tube for kinks
    • Test the float switch
    • Check the inlet valve filter screens
    • Test the water inlet valve
    • Test the drain valve lever arm
    • Check the drain valve
    • Please check each one of these out carefully ok
    • Hope this is very helpful for you
    • Best regards michael
    Jan 10, 2010 | Bosch Integra 300 Series SHX43C0xUC...
    Lf code on whirlpool cabro
    The LF code indicates the washer has taken longer than 8 minutes to fill and as a result has not satisfied the pressure switch that the machine is filled with the required amount of water. This may result from having a low water supply pressure, which can happen if you have a bath, sink taps or hose running while trying to use the machine. This condition can also result if the drain hose is too far into the stand pipe or runs down hill into a floor drain and effectively siphons out water from the machine. Check the drain hose and correct it if either of these are happening otherwise check to see if you really do get enough water flow and pressure on the cold, and if you have a dual fill machine, the hot water supply. It is also worth checking to see if the filter screen at the end of the supply hose is clogged or scaled up in which case you should clean it or descaler it as appropriate.
    Oct 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    "LF" Long Fill Fault Code on Whirlpool Cabiro HE Washer
    there is an electronic timer, did they mention how long the fill should take on average and when the timer signals fill time exceeded?
    Sep 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Only motor goes on, no water
    Hi,,
    try these
    1. Check that the water supply is turned on. The valve may be located under the sink.
    2. Check the door latch
    3. Test the door switch
    4. Inspect the float assembly
    5. Inspect the fill tube for kinks
    6. Test the float switch
    7. Check the inlet valve filter screens
    8. Test the water inlet valve
    9. Test the drain valve lever arm
    10. Check the drain valve
    • please rate my suggestion....
    Apr 11, 2009 | KitchenAid Dishwashers
    WFD 2460 will not start wash cycle after it has filled with water
    Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
    ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
    Dec 07, 2008 | Bosch Logixx WFT 2806 Front Load...
    GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
    851 people viewed this question
    Top GE Dishwashers Experts
    Mike
    Oloyede Monsuru
    Are you a GE Dishwasher Expert? Answer questions, earn points and help others
