Question about Philips DVDR3390/37 DVD Recorder
Won't play dvds.
So far I have had this problem with 2 dvds. My dvd recorder will not play some dvds. I bought legitimate copies of Pursuit of Happyness, and Superbad. Both times it gets to the main disc menu, but when you press play, the timer on the recorder only gets to 00:02 and then it just stops. My guess is that there is some kind of weird copyright protection on those dvds that stops them from playing in a dvd recorder, but who knows...
  • 4 more comments
  • apwsimi Dec 29, 2007
    will not play EL CANTANTE, have tryed 3 copy's, 2 from Netflix 1 from local rental store.
    apwsimi@sbcglobal.net
  • jfayers3 Jan 02, 2008
    I have the same DVD player/recorder and mine does the exact same thing with the Superbad DVD. Gotta be some weird encoding.
  • dan8152 Jan 14, 2008
    yea it won't play a lot of the movies that I rent. Very upsetting as it's a new player. I tested the theory about some kind of copy guard and it's true. Just rented "war" and it would not play on my NEW DVD player so I had an old DVD player ($19.99 special) and plugged it into the front rca jacks and the movie played all garbled and kept losing sound. pluged the cheapo DVD player straight into the TV and played fine. Class action suit? They are wasting our time and money as it won't play many new movies. I got it to record my old VHS home movies and be my ONLY DVD player. Now I have to go get my old $19.99 player to play any new movies
    so add superbad and war to the list of new movies that won't play
  • Anonymous Feb 09, 2008
    I have had this exact same problem. It is not the DVDs themselves. The DVDs will hang up in the Philips player. I can turn around without having done a thing and play those same discs in a different player.
  • iaguy Feb 13, 2008
    Same here! Superbad stops at 00:02. I have had the same problem with other DVD's although I can't remember their exact titles now. At first I thought it was just a scratched disc but have found it's the player :( Emailed Philips support and no surprise they were no help! Superbad played just fine on my laptop. Anyone know if they will release an update to fix this problem?
  • Ahnicka Feb 16, 2008
    I've had the same problem with the exact same movies. I just bought another movie today and tried it. And it stopped at 00:03. Super bad stops at 00:02 also. And my dvd player is also new. It's frustrating because I try to return the movies and the movies play fine at the video store.
Hi, All. I found this discussion based on a Google search because I was having the same exact problem with playing Superbad on my Philips DVDR3400 after renting the movie 3 times and confirming the DVD played on my computer, etc. The good news is I was able to fix this problem. Go to Philips support at http://www.support.philips.com/support/html/index_us_en.html From that link, enter the model number of your DVD player into Search. Select your player from the list that comes up, and on the next page select "software & drivers" link at the left. This will take you to the firmware upgrade for your exact model which updates the software that runs your DVD player (also, when trying to find your exact model..such as mine was DVDR3400/37...you can find it on the label on the underside of your DVD player or it is on a sticker on the back side of your user manual). This takes you to both the link for the software download as well as detailed instructions on how to do it which are very clear. That includes how to use your remote to check that the version you will upgrade to is newer than the current version on your DVD. This was quite easy so long as you are comfortable with downloading the software to your PC, unzipping and then ripping to a recordable CD disc. You will then put that dics into your DVD which will read the files and upgrade itself. The whole upgrade process on the DVD itself took about 5 minutes. When it was done rebooting after it upgraded, I powered it off/on. Then I played Superbad, laughed and had a good time ;)
Posted on Feb 17, 2008
I've had the same problem with my DVDR 3390. The movies that it would not play were "The Eye" and ""3:10 To Yuma". The only thing I could find that the movies had in common were that they were both Lionsgate DVDs. My firmware was the same as the download offered by Philips.
Posted on Aug 18, 2008
I'm actually on the phone with Philips support as I type this. I'm having the same problem and went to the web site in order to do the firmware upgrade. Well, when I checked the firmware on my unit (DVDR3390), it's actually a bit higher than what's posted on their site and my unit was built in May 2006!
The movie giving me an issue is "The Eye", which is currently a 2008 new release. The Philips support guy doesn't seem to know the status of the firmware and instead is asking me to find my receipt, fax it to them and they will replace the unit. He claims that he's spoken with two lead techs and they think that my laser is weak. To be honest, that solution doesn't seem likely to me since firmware has fixed previous problems and most all other discs work just fine. This is probably the 3rd time that I've seem this problem although I can't remember the names of the previous discs with the problem.
For those who want all of the details, the firmware that was already on my unit is as follows:
DVDR3390_37_V03_20
Drive: 51.05.02.06
Build: 0091 May 15, 2006 <-- clearly 2 years old
The firmware currently on their site is the same except that their drive firmware appears to be lower:
Drive: 51.05.02.05
My guess is that this is yet a new problem that they are not aware of and will require another firmware update. Like others have reported, when placing the disc into my cheapo $19.95 DVD player, it works fine.
Posted on Jun 09, 2008
The link on Phillips seems to be dead once I click on my model. I get a server error. I've probably spent 12 hours on this and I'M GETTING MOVIES LEGALLY. They wonder why people pirate them.
Posted on Jun 05, 2008
Best
Posted on Feb 18, 2008
    Problem Solver:
  • 7 Answers
If this device will play other DVDs, try playing the problem DVDs in another device. If they play, and your recorder will play other DVDs without problems, your guess is probably correct. It is also possible that the problem can be in your drive, or the discs themselves.
Posted on Dec 08, 2007
My Sony dvp NS710H isn't playing most standard, well conditioned DVDs.
Hello
Just clean its laser pickup lens, by inserting a lens cleaning disc in to, and play it at least two times. If it doesn't help you, the laser pickup unit should be replaced. The lens cleaning disc can be bought from most of the electronic sparepart selling shops at your town, and won't cost more.
Feb 27, 2012 | Sony DVP-NS710H/B DVD Player
DVD player does not recognize DVDs.
if your trying to play dvd r or dvd rw ( copy dvds ) some dvd players wont play them. but if its original dvds your trying to play, try using a lens cleaning kit
Oct 12, 2011 | Panasonic DMR-ES46VS DVD Recorder/VCR
How to transfer Panasonic DMR-E80H recorded DVDs to computer
I have to agree with XELIAM regarding finishing the disk, under the DVD "FUNCTIONS" selection from the remote. I also use the SLYSOFT products to transfer my videos to what ever other mode of video I wish to have, whether iPOD (MP4), or DIVX (AVI) or loads of other options. Slysoft makes a GREAT product
Dec 04, 2009 | Panasonic DMR-E80H DVD Recorder
Copying to hdd problems
Its not easy to copy a DVD, unless you have the proper software. Even then there is a lot of trial and error that you have to go thru. My suggestion is to findout whats the recording software that are used by both of the recorders and try to get around them by means of a computer.
Or alternatevly do the recording via a computer.
May 19, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
1}DVDR 3480 playback on many Dvds widescreen insteadof 4.3 as set. 2) my Vcr. has 3pin phono. Dvdr scart to Phono .Xt2 says nosignal. Phono tophono (cam socket) no signal .cannot copt tape to DVD. 3)B W...
1) The 4:3 / 16:9 option only optimises playback for that particular type of TV. The 4:3 setting also allows you to set the output between:
  • 4:3 PS - expands the picture vertically and horizontally which gets rid of the black bars, but you also lose the left and right edges of the picture.
  • 4:3 LB - Letterbox format, displays the full picture from the disc, with black bars top and bottom.
The PS option loses the bars on 16:9 widescreen DVDs, but may still leave bars on true cinema widescreen DVDs, which are 21.7:9
This is normal.
  • 16:9 - Optimises the picture for a widescreen TV. Again True cinema widescreen DVDs will still have black bars.
2) All of the external inputs will show "No signal" until there is actually a signal playing into them.
EG to copy VHS to DVD, you will need to select the relevant scart or phono input, and press play before the recorder will register a signal and allow recording.
Some bought VHS videos have copy protection, and may cause problems when copying to DVD.
3) Greenish playback maybe caused by colour setting on TV being too high. Also check Hue or Tint settings on the TV, if it has them.
4) For some reason, in their infinite wisdom, Philips omitted the Video Plus facility from this model.
Apr 28, 2008 | Televison & Video
Won't play dvds.
Model number of the DVD player would really help...\
Bill
Apr 09, 2008 | Televison & Video
Samsung DVD-V$357 recorded dvds won't play on other machines
Did you finalize the disk? If not, this should solve your problem. When the disk is finalized you should be able to play it on your computer if you can play other DVDs on it. Some other DVD players can only play specific disks (i.e. DVD-R, DVD+R). This may be another problem.
pjrsop
Mar 14, 2008 | Samsung DVD-VR357
Playing recrded DVD's on other devices
are the dvd devices you are trying to use able to play copies or not as alot of dvd players are restricted and wont play copies let me know if you need further assistance
Nov 26, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
SONY Model No: DAV-D150G DVD play problem!!
dav-dz100 a disc cannot be ejected and locked
Oct 06, 2007 | Sony DAV-DZ100 System
Philips DVDR3390/37 DVD Recorder Logo
688 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
