Question about Maxtor OneTouch II external hard drive 300GB 7,200 RPM - USB (E04H300)
Dropped my hard drive got knocked off my desk and landed on the ground. when i plugged it back in there was an odd noise followed by beeps. i opened it up to see if i could spot the problem but the noise is coming from inside the disk itself and i don't want to risk opening it. does anybody know what my best bet is?
  • 749 Answers
Sad to say but your hard drive was already damage badly! the head might have already scratched the cylinder. it is very sensitive! no other good suggestion i can give you! sorry! buy another!
Posted on Dec 05, 2007
When i plug in my lacei 500gb all i get beeping tone what is the problem where can i repair
Your HDD might having a problem,have you ever try another hard drive for a test? or trying to plug-in your hard drive to another computer?
Symptoms of hearing a beep or other extra noise is that;
* when your Hard drive fell or dropped on the ground
* spinning fast up and down
Chances to be recovered by;
* plugging in to another port
* format the Hard drive
Good Luck....
Jun 28, 2011 | Computers & Internet
My iomega external hard drive just beeps when ever i turn it on. How can I fix this?
ummm, i fixed my problem i had with a iomega 500gb external hard drive, it was beeping at me also, so what i did was i knocked it on its side, switched it off, by its own panel, then switched it back on, it came back into life and was recognised again!!
so try it with yours!
I think what what happens is, when you accidentally drop it, or knock it from time time(accidentally), the needle inside the hard drive goes out of place, and the hard drive will beep, or something to that effect. knocking the case itself again, might fix the problem, or maybe not, thats if the hard drive itself is more severely/inherentally faulty.
Apr 11, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
When plugged into USB slot, Beeping annoying sound to begin with, followed by light flashing and Hard drive not being detected. Thanks
This issue is related to the hard drive, Have you dropped the hard drive at any time recently? If so then you may have lost your data. Since the hard drive is makeing a beeping noise then the head has died meaning the hard drive is dead hope this helps.
Apr 08, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My hard drive was knocked of the table and landed on carpet
Computers do not like being dropped especially when it is powered up and running. It can do a heaps of damage.
If the hard drive in the computer makes a clicking sound and it won't boot up and/or an error message says it cannot find the hard disk or operating system, then the hard disk is damaged beyound repair.
With luck if the hard disk is only damaged then you can replace the hard drive and install Windows on the new hard drive with the device drivers and your programs. Your data on the old hard drive is gone unless you backed up your data onto CD, flash drive etc.
Sep 29, 2009 | Maxtor Fusion 500GB External Ethernet...
Knocked over Seagate 500GB FA Pro Makes Beep Noise/Can't Connect
it sounds like the disc (inside the hard drive casing) has become jammed or what is known as "stickation". the best way to unstick the disc is usually another sharp blow. the best way to do this is to remove the drive from the external casing and, while holding it by one side, strike the other side downward onto a hard surface like a wood desk. do not strike it on metal or cement as you may cause more damage. make sure the surface is softer than the drive casing. it sounds extreme but it has worked for me on several occasions.
Jul 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I dropped my Western Digital 1TB [(2) 500 GB?] book on the floor now it won't boot up, and it makes strange clicking sounds like it's trying to, but no go. Is there hope? I have a WD My Book 1 TB Home...
The drive is indefinately junked, however I would not fully give up as it may still be honoured under warranty. The warranty is great on these drives. As for the information I would not worry too much about any one reading it off thats a lab job. If you don't want to pursue warranty and still want to destroy the data then open the drive(s) up and you will find very conveniently inside a VERY strong magnet which you could run over the platters. The magnet is hard to get out because of its magnetic strength but its located at the pivit point of the head arm.
If this info is handy rate me kindly
May 08, 2009 | Western Digital My Book Essential 1TB...
Maxtor Personal Storage - beeping noise
consult the authorized service cenetr of amxtor as they can recover data from damged hard disk . carefull while connecting to pc . as it can damage pc if circuits are broken
Dec 03, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Damaged Maxtor Cable Socket
NO. Its also probably the drive a suffer physical damage. Imagine a cd player being dropped as it is reading/writing, except you can change the disk. You will most likely have to ( or have a trained technician ) extract the drive, place it into a new enclosure, and test the drives stability. Hope this helps.
Sep 26, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor OneTouch II external hard drive 300GB 7,200 RPM - USB (E04H300) Logo
65 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
