Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Problem my colors don't work properly and the picture is not clear
  • 4 Answers
Nothing you can do yourself. Convergence has failed and technician have to have a look at it. TV will need 2x convergence chips replaced as a very least.
Call me on 0414 635 468 if in Melbourne.
Posted on Dec 05, 2007
This pictures are not clear whats wrong with the camara
Please select the appropriate shooting mode depending on the light(day night, interior or outside), select the highest resolution, remove all additional features if they were set to ON MODE. If confused with settings RESET the camera to factory settings. it should work properly.
May 17, 2012 | Nikon COOLPIX S610 Digital Camera
Hello and Welcome to FixYa!
Sir, if you have installed Color Cartridge but if you are getting the message about not finding the color cartridge then its means Color Cartridge in not installed properly.
Please follow the following steps to install the cartridge again.
1. First of all Confirm that the printer is powered on.
2. Open the card slot cover and then the front cover. The cartridge holder moves to the replacement position.
3. Remove the cartridges.
Note: Handle the cartridges carefully to avoid staining clothes and surrounding work area.
4. Insert the cartridge into the cartridge holder.
Note: Push up the cartridge until it clicks into place.
6. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
Now check the printer again. If you still get this error message then it means the Cartridge you installed is not exactly proper, or if you think that u got this cartridge from the reliable source and it is proper and exactly fine cartridge then the problem is in the Print Head. You need to check it again.
I hope you have a clear picture in your mind.
Don't hesitate to let me know if you have some confusion.
Sir, Your Rating for this solution as Maximum Stars and words of appreciation will be esteemed.
Thank you for taking my service.
Concerned: Muhammad Uzair
Nov 02, 2011 | Canon PIXMA iP90 Mobile Printer
I have what I think is a Hitachi 55 inch ultravision rear projection TV that is 12 years old. I think the model is 55UX58B. The color goes out and it becomes black and white. It comes back after a few...
When the tv is it totally black and white and the tv picture are good and clear wright?when the tv colors are fade in and out are clear up and when the tv picture it is in colors it is look good normal picture wright?Tv have no shadows of any kinds of colors when picture are good in colors wright?Yes,take ur hand make fist or take a wooden hamer bangs all around the tv bazel frame if the tv colors come back or tv stay in colors it is have good picture in colors.Tv it is still good just have components parts are cold soldering or CRT colors guns R,G,B just require resoldering works only.
Aug 22, 2011 | Hitachi 50UX57B 50" Rear Projection...
My HLP6163WX/XAA has the grinding sound inside so I'm going to attempt to replace the color wheel. I haven't lost picture yet. The picture and color is still perfect. What I'm worried about is...
All you have to do is install the new wheel. Once you do, if the picture is all solorized, then pull the little jumper out of the back of the light engine. You can see it as soon as you take the back off.
Jun 28, 2011 | Televison & Video
I woke up to find the that the picture looks like a blob of changing colors. the sound works find for the picture looks like just water colors swirling around
HGi, Unplug TV for 30minutes and then see what happens. If it clears up you are good to go. If it does not. Have a repairman look at it. Also check all connections for proper connect. Good luck.
Jun 15, 2011 | Insignia NS-P502Q-10A 50 in. HD-Ready...
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
Inherited Compaq FS740 but after hooking up monitor will show green for a short time and then color is yellow? Is it dead? Has set up for a while
Check the pins on the cables. Single color presentation but clear picture indicates the pin for a particular color is borken on teh cable. Remember Red Green and Blue are mixed to make other colors. If you have predominantly one color then its due to cable not haveing all pins inserted properly or damaged.
Jun 28, 2010 | Compaq fs740 17" CRT Monitor
Blurred color images
I'm not sure of what brand and/or model you have, but most have a maintenance mode to do color alignment.
Jul 16, 2009 | Office Equipment & Supplies
Color Alignment HP ScanJet IIcx Flatbed
u change the cable of your scanner and connect to new cable and install all the drivers and software properly your scanner working properly
Mar 18, 2008 | HP ScanJet IIcx Flatbed Scanner
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
