Tv won't stay on
  1. tv keeps shutting itself off while playing. It will come back on after being off for period of time. It is a 51" RCA HDTV.
    President:
  • 4,402 Answers
Need model number#, sounds like loose connection or cold soldering joint or a part is over heating.
Posted on Dec 05, 2007
RCA LED42C45RQ 42" LED LCD HDTV Shutting Off by itself
These flat panel tv's from china have cheap capacitors. Check to see if any capacitors have pushed up top, this indicates blown or dry capacitor. Replace with exact value, in the power supply area (is where they go bad). TV has a monitoring circuit, and if standby (or ready voltage) is not adequate, tv will shut off or stay in standby mode. Little tired today, so hope that gives you an adequate answer.
Feb 14, 2014 | RCA L37WD12 37 in. LCD HDTV
RCA 50: HDTV, just started shutting itself off and won't come back on for several minutes or over an hour what could cause this
My friend had the same problem. There is some display bulb that is on its way out. They aren't cheap. Find a 2nd hand TV parts/repair shop, They usually have cheap used ones from discarded units, and will know what you need!
Sep 16, 2012 | RCA Televison & Video
Hi, I have an RCA HDTV SRS WOW Model RCA L32WD12YX5, Serial G482CJ060. It powers on and has sound for about 15 minutes then shuts itself off and restarts with no sound. As an experiment, I used the Menu...
The tv main Tuner signal board have problems and the causes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Jun 09, 2011 | RCA L32WD22 32 in. LCD HDTV
Turned on the tv, heard sizzling sound and it immediately shut itself off. Won't turn on now. It had been turning itself off periodically now and then for the last couple of weeks with no noise and then...
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
Oct 28, 2017 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV turning off
INtermitant problems as the are called usally mean bad solder connections...the joints between electronic components. this set when it has a problem shuts down. This is safty cuircits. It could be a connector. when the set shuts down. it locks out for a period of time.. DO you have to uplug it to reset it? IS there any sounds. Without know more i would guess its high voltage.
Dec 06, 2007 | RCA HD52W56 52" Rear Projection HDTV
Screen TV shuts down
Sounds like an electronic part (a resistor, a diode, etc) that stops conducting electricity when it heats up to a certain point. Maybe it physically loses contact on its circuit board due to a bad solder, or the part itself is internally defective. Unfortuantely you'll need an expensive professional repairman to diagnose it. TVs have high voltages, ya know, and can kill you if you go mucking around inside.
Feb 24, 2007 | RCA D52W19 52" Rear Projection Television
Tv keeps turning off
If it's staying on for just a short period of time it sounds like there is a sensor that is giving the unit a faulty condition (Perhaps for reason or due to a fault in the sensor). There are normally a few temp sensors in the TV around the Lamp and Ballast. They may be bad, or the lamp or ballast is just generating too much heat.
Feb 05, 2007 | Panasonic PT-45LC12 45" Rear Projection...
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
