This printer is basically brand new, I bought it in September, and it's sat on my desk safely since.
Yesterday I printed out a page fine, it grabbed the paper and printed out at lightning speed as usual. I'm a college student, I don't use the printer heavily, but I use it from time to time. Also, no one tampered with the printer since I don't live at school :-)
Today, it will not feed the paper no matter how many times I try. I've fanned the paper out, I've used everything from one sheet to many sheets, it just won't roll the paper through. And it's making a weird sound too, like a low grinding shrieking noise. While I don't know anything about printers, I know that's definitely not a good sign!
Luckily I discovered the lower paper try beneath where the printed paper comes out, so it's a temporary solution, especially around finals time.
Any ideas on what is wrong with this printer? Visually, I can't see anything stuck in there. As I said, it worked perfectly yesterday, no scary sounds either. I got it at Best Buy... I guess I might end up taking it there, I think they will fix it for free or send it away and I won't see it for a month... not so sure how to proceed... perhaps there is something I can do to fix it myself, like if the "rolly thing" that catches the should be in a certain position or something?
Hello again everyone -- I just figured out my problem and successfully fixed it! Very relieved.
It turns out that I needed to clean the roller (I searched around on the Canon's help site) To check out the link for yourself: Clean the Roller
Here are the steps:
Issue: Paper does not feed through printer
Solution: Clean The Paper Feed Rollers Using The Operation Panel - MP600
Clean The Paper Feed Rollers Using The Unit's Operation Panel
If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
Use the button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
Press the (A) button.
Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the button.
Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press .
Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press .
Use the up / down cursor button to select [Yes], then press the button. (The paper feed roller cleaning starts.)
To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
Use the up / down cursor button to select [Yes], then press the button. (Paper will be fed.)
Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Press the button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the is set for that paper source.
ASF
The above illustration shows a PIXMA MP500
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Here are the steps:
Issue:
Paper does not feed through printer Solution:
If
Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
Press the <HOME> (A) button.
Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
Cassette
You can't post conmments that contain an email address.
The above solution is very detailed and informative. It's great. Thanks. Also, a good first step is to check the paper feed to make sure it is set to the correct loader. Sounds stupid but easily overlooked.
check first if printer work fine, you can test print it manually, then check if computer communicate with the printer by allowing to remove driver and insert usb cable it must be popup that found new hardware occurred for its detecting printer. reinstall back driver, restart and send print test.
After reading through earlier problem fixes, I inserted a piece of Card right through the feed system then taped all the covers and loose paper feed trays closed with masking tape.
Picked the whole unit up, turned it upside down and shook it up and down and side to side quite hard.
Put it back in place on the desk, undid all the tape and plugged both cable back in and switched it on. It went through a long startup process, spat out the card sheet and has worked OK since then (about 15 sheets printed).
Thanks for all the ideas in earlier fixes.
get some paper towels and boil some water put in in an old coffee cup. hold the ink cartridges over the water (not in) the steam will clean out the nozzles on the cartridges. the ink will run a lil bit (hence the paper towels) give the printing a go again.
First clean and align the printer correctly. You will need to ensure that you have selected Photo Glossy Paper for best results. You will also need to adjust the gamma settings and also play with the colour saturation controls to achieve a good colour balance that you are happy with. Try printing a basic colour additive chart and comparing screen against printout and adjusting settings as required. http://en.wikipedia.org/wiki/File:AdditiveColor.svg http://upload.wikimedia.org/wikipedia/commons/archive/6/67/20071203133356%21CIE1931simple.png Also have a look at myPANTONE colour splash to get the definitive Pantone Colour Mixes at http://www.pantone.com/pages/pantone/pantone.aspx?ca=24 or use a paint tool or PhotoShop etc to create solid colour blocks of basic colour to compare against.
I had a similar problem; paper would go sideways when it was trying to pull it through. I looked into the paper slot with a mirror and found a mini-blind clip had fallen into the printer. I tipped the printer over and shook it out and it worked fine.
Experienced the same problem a few months back with my new MP600 .. had to take it to an authorised repair centre where they replaced the print head .. all good since
yes, it is very likely an extra screw that was accidentally placed in the box at the factory just before shipping. I have come across this dilemna with other new, unopened things.
(A) button.
button.
Here are the steps:
Issue:
Solution:
If
Use the
Press the
Paper Source
Press the
ASF
Cassette
