Question about Palm Treo 600 Handheld
Setup When i turn on my palm and i get to step one. When i have to touch the stylus in the lower corner it wont pick it up. Anything i can do?
  • 1 more comment
  • Sam_2 Apr 13, 2008
    I am having the same problem with my phone that when I turn my phone and it says to touch the screen with the stylus it will not responed to it. What do I do?
  • PalmYa Apr 21, 2008
    Yeah, I can't figure this out and it's making me angry. It says to touch the bottom right area of the screen with the stylus, so I do it. Then it says to touch the top left of the screen, so I do it, and it says "try again." And I go through this over and over and never get past it. I've tried turning it off and back on, hard restart. There's not much else I could think to do, does anyone have a solution???
  • kimb234 Apr 22, 2008
    My son just bought a treo 600. Same as above, the touchscreen does not respond whatsoever. Of course we got it on ebay, so there's no warranty...is it just a paperweight now, or what?
I tried everything, even heating my Palm as described here.
The only thing that really worked for me was pressing the "up" button while pressing the "Reset" button (hard reset). Luckily, I had all of my files backed up. The hard reset truly worked. Good luck to all!
Posted on Jun 20, 2008
    Novelist:
  • 170 Answers
It is possible that the touch screen "digitizer" is damaged. These are relatively cheap to acquire and replace.
You can try to tap on the area and slowly start making adjustments inward until the tap is registered and accepted. Once the phone allows you to pass this step, you can try to recalibrate the screen from the preferences.
A hard reset might do the trick if the phone is registering a "tap" and giving the error message. If the phone is not registering the "tap", then the digitizer needs replacing.
Posted on Apr 29, 2008
    Problem Solver:
  • 7 Answers
Hard Reset your phone
Posted on Jan 10, 2008
Volidog, you save my life, although the touch screen is not working quite right, but the phone & PDA function is OK. I can move around using buttons, no problem. At least, this can buy some time for me to look for a replacement. Thank you .....
Posted on Apr 10, 2009
I dont have the owners manual for zire m150 and cant get past the touch the target . it asking me to used stylus to tap center of target.. i did and it just goes from upper left corner to lower right...
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Jul 17, 2011 | Palm Zire Mono M150 Handheld
My Palm Zire M150 touch screen is badly misaligned. How do I reset the alignment?
the screen says use stylus to tap center of target ...i do that and it goes to upper left corner i tap and it goes lower right corner and back and forth between the to corners?
Mar 01, 2011 | Palm Zire Mono M150 Handheld
HP LaserJet M4345 - The printer display is mangled, the touch screen does not respond properly to commands. Is there a way to reset it?
Calibrate the control panel
Use the following procedure to calibrate the control panel:
1. Turn the device off.
2. Press and hold the # key and the C key.
3. Turn the device on.
4. When a small white square appears in the upper-left corner of the control-panel display, touch
the square with a stylus.
5. When a small white square appears in the lower-left corner of the control-panel display, touch
6. Allow the device to finish the boot process.
Hope this helps.
Jan 25, 2011 | HP LaserJet M4345 MultiFunction Printer
Touchscreen doesn't respond
Your digitizer has whacked. Has this been solved
Dec 31, 2008 | Palm Z22 Handheld
Palm Tungsten E/E2 digitizer - fragile?
Palm one is in trouble because of problems like this. They don't work on it but you can buy parts to try it yourself. I never had the problem myself but similar conditions. I do windows based units now.
Dec 30, 2008 | Palm Tungsten E2 Handheld
Pen won't work on Quantum Leap Exporer Globe
ok, last night I was doing some research on my daughters leapster, its not a quantum leap, but maybe can be fixed the same way. I found out that you can "recalibrate" the machine. I used the instructions for the leapster, but here is what they said about the Quantum:
Turn the power on. Wait until you see the "Home" screen.
Find the small hole in the back of your Pixter unit above the battery compartment door. That’s the calibration hole.
Insert, push and hold the stylus in the calibration hole. Turn Pixter over so that you can see the screen. When you see two plus signs, remove the stylus from the calibration hole.
First touch the plus sign in the upper left corner with the tip of the stylus.
Then touch the plus sign in the lower right corner with the tip of the stylus.
GOOD LUCK, HOPE THIS WORKS FOR YOU, I ALMOST THREW MINE OUT TOO AND NOW IT WORKS.
Nov 19, 2008 | LeapFrog Leapster Electronic Book:...
Palm Zire 72
You have a bad connection, or no connection to the digitizer. This is common when changing out batteries. Re-open the case and check the connector to the digitizer.
Nov 01, 2008 | Palm Zire 72 Handheld
Leapster with broken pen
My daughter did the same thing to the tip of her Leapster 2 stylus. I called Leap Frog at 1-800-701-5327 and was able to order a replacement stylus directly from them on credit card for $5.00 shipped.
I also took her old stylus and sanded the broken tip down with 100 grit and then 220 grit sandpaper to get rid of the sharp, cracked point and it works just fine. I figure I'll keep the sanded one as a spare in case she does something silly with it again.
Jul 27, 2008 | LeapFrog Leapster Electronic Book:...
Palm 700P stylus problems
it sounds like it could be a warrenty issue, if you have restoreed the device and its still not working then you would need to get it repaired or replaced
Jun 11, 2008 | Palm Treo 700p Smartphone
Touch screen doesnt work
try to open the case, clean the screen and the small frame carefully, reinstall and... good luck, mine worked this way.
Sep 24, 2007 | Palm Treo 600 Handheld
Palm Treo 600 Handheld Logo
233 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
