Westell Wirespeed LiteLine 6100  Modem
Problem for Westell Wirespeed LiteLine 6100 (B9961001002) Modem
Port forwording
By bm7702 on Dec 05, 2007
I have the Westell 6100 DSL modem/router. I have a couple programs I need to port forword for. I go into the setup on the router enter all the ports, global and local. Set the ports to the computer i want but it will NEVER WORK. When I go back and look the modem says the ports are forworded. Is there a apply button or a port forword on switch i dont know about. DMZ host is off and I have tried forwording to computer name as well as IP address
Clarification Request
Posted by marked on May 09, 2008
Did you try port triggering instead of port forwarding?
Same Problem
Jun 26, 2008
-   i need to add ports-   Guest
Jun 26, 2008
-   i to -   Guest
Apr 05, 2008
-   I have a friend who just got Verizon and they provided him with a Westell 6100 wired Modeum. He cannot connect to other people for gaming he uses a Links 2k3 Golf Game he can not Host/Join to play with others.
This Modeum was manufactured for Verizon.
the ports we tried to port -forwarding and can't get all the Globle ports put in
the ports are 2300-2400, 6073-6073, 47624-47624
can you help
Bob-   SRIXON
Solution #1
posted on May 09, 2008
Somewhat Helpful)
shaggyrat
Rank: Wiz
Rating: 83%, 794 votes
ok port forward if any has router this is easy ill get too others in momment
routers port forwarding features type in ip address in internet explorer search bar at top
router ip's start like this 192. type the whole ip in
this will ask you for password and that usually is the word "password" or "admin" threw that you can set the router port forward by going down the list
now for comps with out routers
goto control panel
then network connections
right click on your connection
goto properties
goto advanced
goto settings
you will be directed to windows fire wall
goto exceptions add program or port you want to forward
basically port forwarding is a program that keeps 2 comps from having conflict with each other running the same program and helps in monitoring ports for intrussions
Was this helpful?
Yes
No
Popular Solutions for Westell Wirespeed LiteLine
Questions and Unsolved Problems for Westell Wirespeed LiteLine
Do you recommend Westell Wirespeed LiteLine 6100 (B9961001002) Modem?
Answer
Answer
westell modem lights are all on at the same time and flash at same time ?
Answer
I used a shiro ethernet modem And a aztech HL 109 RN wireless/wired router with Homeplug function.... (More)
Answer
i have a Westell VersaLink Model 327W and the light for the ethernet cable keeps blinking... (More)
Answer
umm well my verizon dsl internet light blinks and when i play games they lose connection or lag but... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Westell Wirespeed LiteLine...:
Top Modem Experts
Rank: Guru Guru
Solutions: 3608
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Modem Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
