First of all check your door switch, make sure it is operational.If the door switch checks good, the start switch could be faulty, in
newer dryers the start switch is built into the timer in older
dryers your start switch may be seperate, if you have to push on the
timer dial to start the dryer, its built into the timer.
Check any other safteys that may be stuck open.Double check anyway. If it wont do anything, I would say
its the door switch or the start switch.
SOURCE: Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
SOURCE: ge electric dryer. suddenly stopped working. Will
Hi Stv,
There isn't really major problem, but a problem.
You will need to unplugged your unit and take it apart. Are you handy?
If and when the unit is apart look at the motor and the fan exhaust and see if there is a coin or screw is jamming the motor or the fan
while you are in there you may want to clean it up,
That should be the problrm
