Question about Broksonic CTSGT8118T 13 in. TV/VCR Combo
Transition from Analog to Digital
Hi, I currently have Time Warner Digital Cable and I have the Broksonic TV referenced here.  Will I have to buy a new TV when the transition from analog to digital occurs, or will I be OK since I have digital cable?
Thanks.
    Genius:
  • 1,139 Answers
You will be ok
Posted on Mar 24, 2008
Is the TV Tuner in the 8806 analog only? It cant be used for OTA DTV?
GPX KCL8806DT television receiver has only an analog broadcast tuner to receive digital from Time Warner you will require a converter box.
Feb 17, 2015 | GPX KCL8806DT 7 in. Portable Television
Tv remote codes time warner cable
275,270,274. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls. Surf the sites with patience.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jan 29, 2014 | Broksonic Televison & Video
Got the digital set up box from Time Warner Cable but they did not include hook-up instructions.
If you have an HDTV, you can hookup HDMI cable from set-top-box to the HDTV's HDMI input and select that input on the TV using your remote. If you have analog TV, you can hookup using RCA cables (yellow to yellow, white to white). You could also call Time-Warner for assistance.
May 16, 2011 | Televison & Video
TVGOS (TV Guide on Screen) stopped working on Time Warner.
split your input cable line and connect one end to your digital input and the other to your
analog or air input.
Jun 28, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
How do I tell if my tv is analog
Hi Dru,
Good news, your 42 inch Phillips has a built in digital tuner, all you need is an antenna.
Please post the model of your other Tv and I will check on the tuner type.
I have provided a link to a site that has good info on antenna types and the channels you will be able to recieve.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this was the information you requested and please rate this solution.Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 25, 2009 | Philips Magnavox 42MF521D/37 Television
Toshiba TV model 19A24
THAT IS AN ANALOG SET. YOU NEED THE CONVERTER BOX. FOR TRANSITION TO DIGITAL.
Jan 22, 2009 | Televison & Video
Model ctgv2727
Broksonic CTGV 2727 is an analog tv, so you'll need the converter if you use an antenna. If you're a cable tv subscriber, the cable provider will do the conversion on their end and you won't need the converter in that case.
Nov 14, 2008 | Broksonic CTGV-5463TCT TV
Can't program the DVR remote to cut my broksonic tv on or off.
what is the code for broksonic universal remote code
Jun 20, 2008 | Broksonic CTGV-5463TCT TV
Picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
Jan 01, 2008 | Panasonic CT-32D31 32" TV
Broksonic CTSGT8118T 13 in. TV/VCR Combo Logo
96 people viewed this question
Top Broksonic Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
