Kodak EASYSHARE Plus Series 3 Thermal Photo Printer Logo
Posted on Aug 27, 2009
The paper and the ink cartridge are no longer aligned
Anonymous
Level 1:
  • Contributor 35 Answers
  • Posted on Aug 27, 2009
Anonymous
Contributor
Level 1:
Answers
35
Questions
0
Helped
7731
Points
71
You didn't specify what type of printer you're using at... anyway try one of these steps hope it would help.
1. Aligned your paper feeder, coz there are many type of paper: A4, Legal size, letter size, A3 etc..
2. Be sure to properly attach the ink cartridge...
3. Browse the manual or the software of your printer and use the help..
11helpful
My printer is telling me to "press enter to align the cartridge". i did that but, nothing is happening. HELP!
Solution There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective.
Follow the steps below to resolve the problem Step one: Examine the paper the alignment page was printed on The alignment page must be printed on clean plain paper of either letter or A4-size and that has a brightness level (as printed on the paper package) of at least 85. Colored papers or paper that already has printing on it will cause the alignment to fail. Back to top Step two: Does the alignment page print correctly For the HP PSC 900 series, if the page ejects immediately or a Paper mismatch or Paper too narrow message is displayed, the 4 x 6 paper tray selector located on the paper output tray is pushed forward. Move the selector all the way toward the front of the product. Look at the alignment pages that the product printed. Compare the alignment page to those that are included in the "Examples of alignment pages" section in this document. If any of the colors or the black is missing from your alignment page, a cartridge-related problem exists. Click here for information about troubleshooting ink- and cartridge-related problems (buu02176) (in English). Back to top Step three: Perform an print cartridge cleaning procedure The product can perform an print cartridge cleaning procedure even after the alignment message has displayed. Follow these steps to perform an print cartridge cleaning procedure at the front panel:
  1. On the front panel, press the Menu or Setup button (depending on the model).
  2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press the OK or Enter button (depending on the model).
  3. The Clean Print Cartridges message should display on the front panel. Press Enter or OK to begin the cartridge cleaning process.
A page will be printed during the cleaning process with all of the colors on it. If any of the colors (including black) are missing, faded, or streaked on the alignment page, there is a ink cartridge problem. Back to top Step four: Try to align the page again HP products have two methods for aligning the ink cartridges, fully-automatic and semi-automatic. The steps are different for each type. Refer to the information below to determine which alignment method your product uses. Automatic cartridge alignment Perform the following steps to align the ink cartridges:
  1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
  2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
    1. Press Setup or Menu on the front panel (depending on the model).
    2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
    3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
  3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
  4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
tip
Canon MP 460 An Error Message Is Displayed On The LCD
If an error message is displayed on the LCD, take the corresponding countermeasure described
below.
Message Action
There are no photos in memory
card.
There are only invalid images on the memory card.
Photo data edited/processed on a computer should be printed from the
computer, not from the camera.
There is no paper. Reload the paper correctly and press [OK].
The paper is jammed. If paper has jammed in the machine, clear the jam, reload the paper in the
machine correctly and then press [OK].
Ink has run out.
U041
Replace the FINE Cartridge, and close the Scanning Unit.
If printing is not finished yet, just press [OK] on the machine to continue
printing in the “no ink” state.
Replace the FINE Cartridge with a new one as soon as possible after
printing finishes. The machine may be damaged if printing is continued
under the ink out condition.
The following ink cartridge cannot
be recognized.
U051
U052
U053
U059
The FINE Cartridge may not be installed properly, or the Cartridge may not
be the compatible with this machine. Install the appropriate FINE
Cartridge. If lines are misaligned or the resulting output is not satisfactory,
carry out the FINE Cartridge Alignment.
Some ink cartridges are not installed
in place.
U075
U076
Confirm that the FINE Cartridges are installed in the appropriate positions.
See “Replacing A FINE Cartridge” on page 75.
The ink absorber is almost full.
Press [OK] to continue printing.
Contact the service center.
The ink absorber is almost full. Printing will no longer be possible once
the ink absorber is full. Contact the service center immediately. Press [OK]
Incompatible device detected. Depending on the model or brand of your device, you may have to select a
print mode compliant with PictBridge before connecting the device.
You may also have to turn ON the device or select Play mode manually
after connecting the device to the machine. Perform the necessary
operations according to the instruction manual supplied with your device.
If the error is still unresolved, there is a possibility that you are using a
digital camera or digital video camcorder that is not supported by this
machine. Use a digital cameras or digital video camcorder compatible with
this machine.
Auto head align has failed. Make sure all required boxes on the head alignment sheet are filled in, and
that the sheet is set in the correct position and orientation on the Platen
Glass.
If the machine is connected to the computer, you can align the FINE
Cartridge using the MP Driver. Follow the procedures described in the
Printer Driver Guide.
The following ink may have run out.
U162
This FINE Cartridge may have previously been used, or the ink may have
run out. The function for detecting the remaining ink level will be disabled
since the remaining ink level cannot be correctly detected. If you want to
continue printing without this function, press [OK]. Canon recommends to
use new genuine Canon Cartridges in order to obtain optimum qualities.
Printer says "incorrect alignment" and
Possible causes of the error you got can be that one of the ink cartridges is low or out of ink or the paper has already been printed on or is colored paper or the ink cartridge is defective.You need to
examine the paper the alignment page was printed on. Does the alignment page print correctly?You need to perform an print cartridge cleaning procedure and Try to align the page again.
The printer suddenly started printing fuzzy text. I think it is out of alignment but when I try to print the alignment page, it comes out fuzzy too. Is there another way to align the printer and take care...
[email protected]
Have error message saying paper is to narrow, load wider paper and press enter, A4 is loaded print options are set to upper tray A4, paper is loaded, cannot clear message
Hello.
That message is indicating that there is a problem with the cartridge alignment.
From HP:There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
Also, use a fresh piece of paper that has never been printed on for the alignment process or the alignment will fail.
Hope this helps.
2helpful
How do I change the ink cartridge on my Dell 810 printer
Ink Cartridge Maintenance Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridge:
  1. Load plain paper. For more information, see Loading Paper.
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows 2000, click Start® Settings® Printers.
  1. Right-click the Dell AIO 810 icon.
  2. Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Align Print Cartridge.
  3. Click Print.
A blue and black alignment page prints.
  1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
  1. Press the Scan button scanicoa.jpg .
The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
Hope it helped.
Tops and bottoms of letters are cut off. I have changed the ink cartridge
Replace the old ink cartridge.
Verify that the unit is on. The On button is lit when the unit is on. If the device is not on, press the button to turn on the unit. Open the print cartridge door. The print carriage moves to the far right side of the unit. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right. Pull the print cartridge toward you and out of its slot. If the print cartridge is being removed because it is low or out of ink, recycle the print cartridge. Remove the new print cartridge from its packaging. Remove the plastic tape by using the pink pull tab. Removing the Tape from the catridge.
  1. Will have Copper-colored contacts.
  2. Plastic tape with pink pull tab ( must be removed before installing ).
  3. Ink nozzles under tape
  4. The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  5. Top & Bottom not printing properly.
  6. Load unused, plain, white letter, A4, or legal paper into the input tray
  7. If coloured paper is loaded in the Input tray when the print catridges are aligned, the alignment will fail. Load unused, plain white paper into the input tray when the Printer catridges are aligned, the alignment will fail. Load and unused plain white paper into the Input Tray and then try the alignment again.
    1. Press 6 to select Tools .
    2. Press 2 to select Align Print Cartridge The unit prints a print cartridge alignment sheet.
    3. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK. Now the printer will print properly.
2helpful
My HP printer PSC 1510 All-in-One no longer asks me to align my ink cartridges after a change of cartridges. Now, after a system recovery, it prints an alignment page every time I turn it on, whereas...
The only way to stop this is to press the cancel button, just as it tries to print the test page.
Various people have said the printer won't align (calibrate) successfully unless both ink cartridges are more than 50% full, and until it aligns successfully, it will continue to print the test page on start-up.
It is a total waste of ink and paper, so remember to hit the cancel button when you turn it on.
2helpful
2answers
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
