Question about Mitsubishi VS-60705 60" Rear Projection Television
How can i get parts and drawings
The picture flutters vertically and horizontally i would like to get the schematic drawings to see if i can fix it
  • 1 more comment
  • IAS2977 Dec 07, 2007
    I am having a problem with horizontal lines on the screen. I was wondering if I could just find schematics for the pip board and location.
  • Anonymous Feb 19, 2008
    It really flutters verticaly but not all the time
  • Keith Radford Jul 10, 2008
    My does the same thing flutters horozoinlly what part do I need
    Genius:
  • 1,153 Answers
Change C2C52 10uf@50v and c2p05 100uf@16v
Posted on Dec 06, 2007
UN46EH5300 adjust screen size to get whole picture and closed captions
Sounds like you have it on zoom setting. Go to the picture menu and scroll through the options. Start with 16:9 and try others if this doesn't work. If you've already tried this, you may have to go into screen setting and manually draw the picture in horizontally and vertically - but make sure you've got it on 16:9 and paused on a typical picture before you mess around with these settings.
Aug 22, 2014 | Samsung Un46eh5300 46 Inch 60hz Led Hdtv
How do you fix a white horizontal line across top of Orion TV?
Hello eatkinson,
This denotes a problem with the vertical deflection circuit. This is more then likely the result of the vertical coupling capacitor failing. You will need the schematic diagram of the TV to find the capacitor in question. it is located between the vertical output stage and the vertical deflection winding of the yoke transformer. In addition check the continuity of the vertical winding of the yoke transformer this can cause the same problem. In any event the problem is that the vertical deflection signal is not getting to the yoke transformer or the yoke transformer is malfunctioning.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 08, 2009 | Orion1934 19" TV
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
My tv have picture 5 inch in the horizontal in the center....
Check the electrolitic capacitors in the vertical section for leakage or dry condition. The vertical amplifier IC may also be defective and check for the solder joints around the high power resistors as well.
Jan 19, 2008 | Mitsubishi CS-35505 35" TV
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Horizontal lines across the top of the screen
it is a fault in one of the capacitors in the vertical part of the schematics it is 33uf -160 volts capacitor , dry out and need to replace refer to qualified , regards , plz don't forget to rate thx
May 02, 2007 | Toshiba 27A44 27" TV
Horrizontal fluttering when warmed up.
1. HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB
Oct 18, 2006 | Mitsubishi VS-60705 60" Rear Projection...
No picture
You have an intermittant vertical sweep circuit! It could be the vertical out put IC solder connections on the printed circuit board, or maybe the IC itself has poor connections between the IC and the contact legs that mount the IC, or another componet in the vertical sweep circuit. If you know how to solder and unsolder, work on printed circuit boards, then you shoul have no problem replacing the vertical sweep circuit. Good Luck
Oct 09, 2006 | Panasonic CT-25G6 25" TV
Mitsubishi VS-60705 60" Rear Projection Television Logo
117 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
