Toshiba tv model 42h83
Tv on coax cable , picture all squiggled lines till tv is on for awhile then starts to clear up but not totally . picture quality is great on the dish on color stream hook up
Posted on Mar 31, 2008
Horizontal squiggly lines blurring the picture
If its a Toshiba some years old it is the Hyper board bad---a brand and model number are not indicated on this question.
Nov 03, 2012 | Televison & Video
My Toshiba 42H83 has a scrambled screen for about 5 minutes when it is turned on, if it has been off for a while. Once it warms up, it works fine. I have replaced the satellite receiver but this did not...
ok, you are talking about lines in the picture, it started where it would clear up after a few minutes but now it will slowly take longer?
I know what is wrong.
Oct 22, 2010 | Toshiba 42H83 42" Rear Projection...
My toshiba 42h83 has a shaking picture with a 2 to 3 " green stripe at the top of the screen. How can I fix this?? thank's Karl
Check all wires cables go to the tv,shakes,jiggles might,see the prob.than change the wires cables.Not wires cables,than ur main video board is the prob.must change.
Oct 27, 2009 | Toshiba 42H83 42" Rear Projection...
The picture is all waves ,I get sound and color but the picture is all lines and waves,what part should I get??
To fix the shaky picture on the toshiba rear projection tv model number 42h83. You need to either replace the 13 capictors on the hyper module or simply replace the hyper module itself. It's cheaper to replace the caps, but you'll need decent soldering skills to do this. You can replace the entire hyper module with less soldering skills, but I believe the module costs about $100, maybe alittle more. You can find the entire fix by googleing "hyper module". Good luck and I hope this helps
Oct 21, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 model projection HD tv has a bad wavy picture.
yes it can be fixed call a repairman and have them come out and repair shouldnt cost more than a couple of hundred dollars to fix
Feb 01, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 42 inch rear projection T.V.
this sounds like a convergence loss... the most likely cause of this is what is known as stk's or convergenc ic(chips) have gone bad.. also it cound be the output resistors. most likely need replaced
May 12, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba 42 inch rear projection TV
You likely have a bad hyper board.  As time goes on the lenght of time it takes to get a clear picture will increase and eventually the picture will never clear up untill the part is either repaired or replaced.
Oct 23, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42 in unstable video
Probable PIP sister board.Moderate skill & some tools needed.Advise==get a senior tech near you.
Sep 10, 2007 | Toshiba 42H83 42" Rear Projection...
My 1999 TOSHIBA TP55H60 picture is not clear.
When is this happen? almost 8yr old the unit. In this case did u change the lamp bafore? Its seems that the lamp is dying. Try to use a DVD as ur imput and post here if it had a diff.? Use Audio/Video input instead of Coax (Cable). Hope this may help you
Aug 13, 2007 | Toshiba TP55H60 55" Rear Projection...
Flickering of screen (comes and goes) and weird DVD/reception problems
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Jun 29, 2007 | Toshiba 43H70 43" Rear Projection...
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
