Toshiba CZ36T31 36" TV
Problem for Toshiba CZ36T31 36" TV
I have an older Toshiba 36 inch TV that has a
By patmohr on Aug 27, 2009
I have an older Toshiba 36 inch TV that has a shrinking picture. The bottom 4 inches of the screen is black and the top has about 20 white lines across it. It must weigh about 175 pounds so I'm not about to take it to a repair shop. Should I try to fix it or pitch it? (BTW: I've never opened a TV set in my life.)
Best Solution
posted on Aug 27, 2009
Helpful)
palaboy
Rank: Wiz  Toshiba Televisions & Videos  Expert
Rating: 82%, 1191 votes
hi,
there might be a leaky capacitor or a cold solder on the vertical circuits
of your TV, sometimes resoldering the vert IC resolves the problem
same with the capacitors, but if still persist you might need to replace it.
just be careful if you wish to open the unit, be cautious on the flyback
area.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Toshiba CZ36T31 36" TV
Questions and Unsolved Problems for Toshiba CZ36T31 36" TV
Do you recommend Toshiba CZ36T31 36" TV?
Answer
Answer
need the universal remote code for a toshiba ser; 71569191 tv
Answer
Ok, first thing you should know is that whacking the TV sometimes did help. I used to be able to hit... (More)
Answer
Our tv popped off one day while watching it. Then I turned it back on and it was fine. A few days... (More)
Answer
can hear tv power up with power on crt tube
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba CZ36T31 36" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
