Nikon D70 imprint data on photo.
I need to show the date the photo was taken onthe actual photo. Pictbridge seems the only option but this not what I want
Sorry for the long answer, but this is complicated.
Some photo editors will allow you to set them up to display the date on the photo.
HOWEVER on all digital cameras:
The date taken is part of the image data that is stored in the file, but not as part of the image. If you print directly from the D70, you can set the date and data to print in one of the menus, but this only applies if you print from the camera. There is no way to actually put the date on the image like there used to be in some film cameras. Since the "picture" is now just a set of computer data bits stored on a card, disk, or other medium, the actual picture is defined by the jpeg standard, which is part of the ANSI/ISO/IEC organization. A camera manufacturer could add an extra bit of hardware to generate some kind of laser mark on the digital sensor in the camera, but I'm not aware of any camera that has this. For sure, the D70 does not.
In the various softwares that you can buy to read the file, the information in the file (like the date) can be interpreted and printed any way the software is programmed, including putting it somewhere on the printed output.
Testimonial: "Thanks for the explanation - very helpful! Cheers Doug"
The camera records the date in the image file, but not over any part of the image. If you want to print the date on the image, it has to be done when printing. Check the manual for the printing software.
