Question about Sony Cyber-Shot DSC-P41 Digital Camera
No Image at the back screen
I had to open my DSC-P41 to force the shuter open, when I assembled it, the screen didn't work, how can I fix it? I can take pictures, and download them directly to the computer, but I have to take them using the view finder.
Thank you
When I took mine apart and reassembled it, the same thing happened to me. So I reopened it and rechecked all of the connections. First of all, on all of the ribbon connections, there is a black and a beige part. First, stick your fingernail underneath the black part where the ribbon is supposed to be plugged in and then lift up. This will pop the black part open to allow you to plug the ribbon in well. Push the ribbon into the connection as far as you can, and then reclick the black section back down to ensure a good connection. Once I redid this, the screen worked again. I know thats a simple solution, but don't know if you tried it yet. If thats not the case, then it could probably be a number of things.
Posted on Mar 31, 2008
Memory stick error C13:01 on DSC-P41
Try formatting the stick and try again, sounds like it is corrupted.
Jan 19, 2013 | Sony Cyber-Shot DSC-P41 Digital Camera
ALL COPIES BLANK. NOT LOW ON TONER. ALREADY REMOVED AND SHOOK. D320
probably the problem is in laser shuter or toner cartridge pin in toner holder. But when you try to copy, when paper goes to the drum, open the right cover and produce paper jam, now look at drum for image, if on drum isnt image its laser problem...
If the laser shuter is faulty, these means that when you close the right door, the nose on door doesn't lift the laser shuter and so the laser unit cant write on drum.
If the toner crg. pin is faulty, when you insert toner in holder inside the copier, on right side of toner holder is small circle with pin that contacts the toner and gives voltage. You can apply some wd40 to that circle, that goes in and out when you open or close door.
But, probably is laser shuter... to check him you need to dismantle the copier.
Hope that helps!
Jun 23, 2011 | Canon imageCLASS D320 Digital Copier
How do I turn on the flash on my Sony cybershot DSC-P41 - I forgot how to do this? Tks.
Hello
Ok, here is a link where you can download the manual for this device. Just click on the link below and click in get manual when you are at the site.
http://www.retrevo.com/s/Sony-DSC-P41-Digital-Cameras-review-manual/id/200bh926/t/1-2/
It states very clearly on how to turn on the flash. Hope this can help.
Kind regards
Andrea
Dec 09, 2009 | Sony Cyber-Shot DSC-P41 Digital Camera
Sony dsc-p41 vibration warning stop me from taking pictures
Why is your camera shaking? Go into the setup menu...maybe you can turn the vibration warning off.
Aug 26, 2009 | Sony Cyber-Shot DSC-P41 Digital Camera
Sony Cybershot DSC-P41 Bouncing Screen
First try sqeezing the camera very hard, if that doesn't work slam it as hard as you can in your hand. This usually solves the problem.
Feb 15, 2009 | Sony Cyber-Shot DSC-P41 Digital Camera
Cybershot DSC-P41 vertical lines
i have the same problem my camera says 'turn the power off and on again' and i've dun that but then only function that works is the on and off button.
Nov 15, 2008 | Sony Cyber-Shot DSC-P41 Digital Camera
I'm looking for a tri-pod for a DSC-P41 megaPixels Cyber-shot....... My e-mail addy is Maresy0@yahoo.com
Check few tripods for your DSC-P41 at Sony Accessories Center. Just write " tripod " in search box and see results. Select any one and place online order.
Thank you.
Oct 24, 2008 | Cameras
Cyber-Shot DSC-P41 works at random
Here are some simple things to try first for a camera that won't power on, or in your case powers on intermittently. They won't work for every camera, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Feb 19, 2008 | Sony Cyber-Shot DSC-P41 Digital Camera
I need your help
Lens problem : either a gear box is gone or the lens unit is not properly switching on and hence the camera side is not coming on line and goes into error. If it is the gear box then it is not so expensive to fix ,but replacing the whole lens assembly will not be economical on this entry level model.
Sep 07, 2007 | Sony Cyber-Shot DSC-P41 Digital Camera
Sony Cyber-Shot DSC-P41 Digital Camera Logo
48 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
