Question about Whirlpool LER5636P Electric Dryer
Dryer will start to dry clothes then shut off
My dryer will start to dry clothes then it shuts off. When I wait a while it will run again after it is started then shut down again. Any ideas anyone.
Thanks
  • ttroxler Feb 12, 2009
    I have the same problem, my dryer will run when I first put clothes in as long as they are wet it will dry for 30 or 40 minutes. After they get mostly dry it will shut off then I have to let it cool off before I can turn it on again. Most of the time it will only run about 5 to 15 minutes before it cuts off again. Already checked the lint filter and good air flow. Will I need to replace the motor or just get a new dryer?
  • 883 Answers
Sounds like the over-temperature thermostat is the source of problem. This device prevents over heating by removing power to heating coil when normal thermostat control has failed. Perhaps your model takes it a step farther and removes all power to machine for safety. But this device is "tripping" too early unless you can find that your normal thermostat has failed. One test for this condition is to remove power to heating coil (ONLY) and retry a cycle. If your symptom disappears, then the over-temperature thermostat is faulty. If no change, there is either a faulty controller circuit or an intermittent short that is rising temperature-sensitive.
Posted on Dec 05, 2007
    Problem Solver:
  • 5 Answers
The problem you describe almost has to be the motor. Either it is full of lint, or it is just plain failing. Overheating from lint, or bad bearings [do not oil] will cause motor to run hot. The overheat sensor in the motor will shut down the motor until it cools. Once it cools, it will restart.
Posted on Dec 06, 2007
GE spacemaker electric dryer PCKS443EBWW. Dryer shuts off mid cycle on timed dry setting. Wait till cool down and will start again. Venting is clear, I vacuumed inside and around motor. Any ideas?!
Mark, Could be limit /over heat/thermal fuse/switch, check or have checked by a good repair Tech., diagnosed and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Check when your Dryer Shuts Off Mid Cycle
Whirlpool Maytag Dryer Diagnostic Shuts off mid cycle not heating...
Kenmore Whirlpool Clothes Dryer Repair The Most Common Problem
GE electric dryer overheating shutting down
Jul 10, 2016 | GE Dryers
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
Dryer shuts off before cloths are dry,then then you have to wait about 10 mim before you can restrat dryer..cleaned vent duck to out side2 times to besure it was clean..cleaned venting back of...
Check motor for lint build up around motor. Will cause motor to overheat and shutdown on motor
overheat switch and will restart after cooling down.
Feb 11, 2011 | Dryers
Dryer shuts off when I open door ,but timer keeps running
I had this same problem with my Kenmore dryer. If I left it plugged in and door shut it would eventually turn over and start up again. But now my timer is working properly but my dryer won't heat up and dry the clothes. I need help....
Feb 26, 2010 | Kenmore 63942 Dryer
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
DRYER RUNS ABOUT 15 MINUTES, HEAT WORKS,MAKES NOISE AND STOPS
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
gdhi64
Feb 13, 2009 | Whirlpool LGR5636L Gas Dryer
Kenmore Dryer shuts off to soon.
Might be something lugging down the motor causing it to shut down on overload. Too many clothes,bad rollers, idler, or slides. All can cause the motor to have fits. It might just be time to replace the motor or try and oil it. They don't put any oil holes for the bearings. You must make some. Use high temp oil to fill the bearing wells. Work the motor free. If you are gonna replace the motor remember the blower wheel has backwards threads.
Jan 26, 2009 | Kenmore 63942 Dryer
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
174 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
