Zebra Eltron LP 2824 Thermal Printer Logo
Posted on Aug 27, 2009
My Eltron LP 2824 won't print two labels side by side...it keeps printing across the twolabels...I've tried changing the 'portrait' and landcsape..but nothing happens...
Anonymous
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Oct 11, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
9428
Points
31
Your software drives this...not the printer. What software are you using to print the labels?
Printing on edge
Your software label template does not match the size label your printing on. Make sure your label size IE: 2.25" x 1.25" matches the template size in the software, then perform this calibration:
TLP 2742 is printing blank labels
Zebra eltron LP 2824 printing too light
This could simply be old direct thermal labels. Direct thermal labels have a shelf life of about 1 year from the date of manufacture. After that time has lapsed the thermal coating on the labels begins to dissipate and this will cause labels to print light or faded. You can trouble shoot with a roll known to be fresh. You can get one free here to test Labeldomain com .
If this does not solve your problem then please check this article on 5 common print quality issues and how to correct them Fix Zebra 2824 2844 3842 print quality
Prints label then prints a blank
This is always a calibration or label template size issue.
1helpful
My zebra lp2824 barcode printer does not print, i downloaded zebra lp 2824 from nice label still it not working, when doing print test it will print only some letters....what to do
check the driver, and the setings from the driver. Try ZDesign Driver or seggul driver from WWW.seaguscientific.com, and print the testpage, chech the connection (port) if is seria (com) check the setings speed etc...
Our LP 2824 Zebra printer stalls with red light when printing labels. Tried calibrating but it stalls with solid red light before printing out data
Try another roll of labels? If that doesn't help, it may have a problem with the sensor that checks the starting point of the label. These are old so it's easy and cheap to replace with a similar unit.
Zebra LP 2824 not printing a barcode
check the driver if the length and the with are correct, print a test page, check if come the windows logo and the test from all label. check if the barcode is biguer that the label, if it is, is not appear.
2 solution is to reset printer to factory defult (press button until flash 4 times and relese the button.
Just one of the double tags is printed on
I assume by double tags you mean 2 labels across the roll.
You need to tell your software that the roll is 2 across.
If using the software that comes with the printer, Zebra designer.
Set your label width to twice the single label and copy the barcode so that you have 2 across the label, then print
Labeller not printing in black - appears to be white
possible the ribbon is on the outher way.
The darkness is to low.
Prints half of label
Restart your computer. Turn your printer off and back on again. Restart your software for printing lables. When updating the printer drivers, all software needs to be restarted to make sure that the form controls are working properly.
Zebra 2824
if you see that it is like printing a card. check your thermal print head maybe its not working.
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
