Question about Pioneer DEH-P8200r CD Player
Finding the AUX button
Im having problems finding the AUX option to use an outside source (Ipod)
  • Muscle302 Mar 09, 2008
    I Have the same radio and a similar problem. I know how to switch the unit to AUX but I cant seem to find where to plug it (iPOD) in. Looking at the back of the unit I only see front and rear outs, to my amps, Phone, mic and sub outs. what am I missing?
    Paul L.I. New York
With the stereo on, hold your Source button to turn the stereo off.
The hold the function button, a menu will appear, press function repeatedly until you see the Aux setting, and you will have an option to enable it with the navigation keys.
Once done press your source button to turn the stereo back on, and then go through the varioud sources and ye shall now find Aux as an additional source ;o)
Posted on Feb 29, 2008
Can't get the Cd rb10 to play my ipod.
Most likely the radio itself has to be set to aux input. For instance my pioneer deck naturally has two source settings, cd and tuner. But in the settings I have the option to turn aux input on and then have that added to the sources. You'll probably have to look up how to turn it on from a manual.
Jun 02, 2010 | Pioneer Cd Rb10 Auxiliary Rca Input...
Kenwood Kdc-mp425 will not switch to Aux. Aux cable is connected to the back of the headunit, but no aux option is available on menu for either my ipod touch or my sirius unit. I've accessed the menu from...
Apparently, this auxiliary input only works for a Kenwood CD changer or a sirius radio connection. At least that is my conclusion after finding the same problem. Let me know if you figured anything out on this.
Jun 02, 2010 | Kenwood Sirius KDC-MP425 CD Player
Cannot find the choice for aux input in order to attach iPod
put on standby mode. then hold in "menu" button.
go through the list by pushing the right hand trigger down. there should be an option aux1. change this to turn on and aux input is on the source option.
Jan 25, 2010 | Kenwood KDC-W3037A CD-receiver,...
Cant find aux conection for ipod function pioneer car stereo deh-p6800mp just need help trying to get ipod playing
there is no direct input on this until. although you can purchase the aux input cable from the link i have posted which will allow you to plug in rca's into the rear. after purchasing2.gif this cable, you will have to turn on the aux option in the menu. which you may want to make sure that you can do beffore you order it.
1.with the power on, hold the source button until the until turns off
2. hold the audio button until a menu is opened. (hold function if audio doesn't work)
3. scroll through until you find the aux option and turn it on.
4. turn on the radio2.gif and scroll through the sources and make sure it is there.
or you can order the direct ipod adapter made by pioneer, which will let you control the ipod directly from the head unit itself. whichever you prefer
Oct 06, 2009 | Pioneer DEH-P6800MP CD Player
Can't get auxiliary to work on Pioneer Mosfet Head unit 50x4
you have to turn the AUX input on through the function menu which can be accessed by following these steps
1. with the unit on. press and hold the source button unitl the unit turns of (or goes into demo mode, which is fine)
2. depending on the model that you have, you will have to press and hold the
(volume button or the audio button), until a menu is displayed.
3 . toggle through until you find AUX 1 and AUX 2. i would turn them both on and see which one you have plugged into, then you can go back and turn the other off.
4. once you have change it to ON. press the source button to turn on. the aux option should now be in your source options.
5. also, while on AUX, you can go into the audio settings and turn up the SLA (sound level adjustment) to +4
hope this helps
Aug 26, 2009 | Pioneer 50W x 4 MOSFET Apple iPod...
How do i get my ipod to play through the aux line in? i try changing source but only has tuner / cd / standby Thanks
hi their u might have to go into options on ur head deck try holding down a button to display options and hopefully theirs aux input!!!! and make sure ur pluggin into the ipod is in ur earfones hope that sorta helps u cheers.
May 23, 2009 | Car Audio & Video
MP3, IPOD, CD doesn't appear when I press "Source"
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Feb 24, 2009 | Eclipse CD1200 Car CD/ MP3 Player
Hook up IPOD
I am not sure if the model you have supports iPod control, but if it has an input jack in the front, you can use a cable from the headphone jack into the Aux jack in the front of the stereo and when there is a cable inserted into the jack you will be able to select Aux with the source button.
The other option is to get a kit installed at your car stereo place that will allow you to connect it via 3rd party hardware.
May 30, 2008 | JVC KD-SX840 CD Player
Can't get into AUX source
Are you sure it is an AUX input? According to the Manufacturers Specs, the AUX, is an optional accessory. There is a Pre-Amp connection, which would be an output, hence causing the problem you are having. Best of Luck.
Sep 13, 2007 | Kenwood KDC-MP232 CD Player
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Jul 01, 2007 | Kenwood KDC-MP628 CD Player
Pioneer DEH-P8200r CD Player Logo
350 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
