Question about Mitsubishi VS-60609 60" Rear Projection Television
Mitsubishi VS-60603 60 inch Projection TV
Hello
I am wanting to move my 60 inch TV from the Living room into a bedroom, but the mirror that sticks out from the back of the cabinet makes it 30 inches wide. My question is...Does the mirror slide into the Cabinet? If so, the TV would be only 21 inches wide and it would be able to make the turn into our hallway to the new location. I have removed every screw from the back of the TV and the piece that sticks out won't move?
Any advice would be appreciated.
thanks
Mike
Indiana
I have a mitsu vs-60603 that when it is turned on all i get is the half screen with red green and blue no picture of any kind what do i need to fix this problem is it posable to switch over to the pip moduale and just use that as my main screen board?
Posted on May 11, 2009
    Genius:
  • 1,153 Answers
You would have to completely take the Mirror out or Mylar backing and being careful not to damage anything, trying to move and reassemble when you get at the new location.
Posted on Mar 13, 2008
I have anrca hdtv model # R56WH76 and I don't know how to set it up with my cable. I have the dish network box in the living room but this rca tv i have in my room with the cable coming out from the...
To watch Dish Network in your room there a couple of different ways to do it. Unless that cable coming out of your wall is connected to a Dishnetwork reciever its useless.Now if the reciever in your living room is a dual tuner dvr than you can run a cable from one of the two outputs to your bedroom. In this scenario you can watch different channels at the same time. If it isnt a dual tuner then you can actually put a splitter on the cable coming out of the box to the tv(has to be on cable coming out of the reciever) and run it to your bedroom. In this scenario both tvs will show the same channel.In both cases you need a UHF remote(dual tuner DVRs come with one UHF and one infrared) that will allow you to change channels while in your bedroom. If you want HD programing on both tvs you will need to contact Dish Network to get a second reciever. its $7 more a month for a second reciever.
Dec 19, 2010 | RCA R56WH76 Projection Television
Brought new tv for bedroom freeview inc..set up
If you have got a good aerial, the high gain type- see image, it should run all the TV's you say. Make certain you have decent cable coming off the aerial (the stuff they use for satalite dishes). Then buy some high quality splitters, to feed the TV's. Don't split the cable outdoors!
Jan 25, 2010 | Televison & Video
I HAVE DISH NETWORK HOOKED UP IN LIVING ROOM, I WOULD LIKE TO ADD IT IN BEDROOM OFF OF THE SAME RECIEVER. I USED A SPLITTER, THE PICTURE IN LIVING ROOM IS CLEAR, BUT REALLY FUZZY IN BEDROOM. I KNOW THEY...
You will need to split the signal with a 900mgz splitter between the living room and other room. if your pic is fuzzy you have a bad splitter or bad cable, try replacing these one at a time and it should clear up. If your getting a sat pic but ti is fuzzy its for sure in the line somewhere fro teh splitter.
Nov 16, 2009 | DISH Network ViP 612
Problems moving the router and getting the internet.
your bedroom cable phone plug has issue.
These is not dial tone or low voltage problem in line.
So just replaced that phone cable and jack .then check.
Aug 07, 2009 | Linksys WAG200G Router
Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue.  The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device.  And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room.  This may require closing a door or drawing heavy drapes closed.
Mar 03, 2008 | Logitech Harmony 880 LCD Remote Control
How to remove the mirror casing
The mirror on this unit is fixed and there is not a method to drop the mirror.
Feb 23, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi Model No VS-5069
You will need to contact a glass place to cut a new mirror that has the reflection paint on the outside of the glass instead of what most mirrors have them painted on the opposite side . Good luck
Jan 15, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mirror
There is black insulating foam that surrounds the projector and it may be displaced to one side.This leaves about an 1 inch opening around the projector lens and that could be the source of the problem,dust being blown into the compartment with the mirrors.
Cleaned the mirrors really well and used double stick tape to reattach the foam to the plastic frame and this will closed off the opening that maybe letting the dust into the mirrored area of the TV.
Nov 12, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Thomson dsi 4200 satellite receiver
The only way this would work ( and this applies to any form of cable/satellite box) so the only way this works is if the TV that has the satellite connected to it has a video output normally indicated with the color yellow, but you still need sound that normally is the red and white (RCA cables). So the first tv needs to have video and sound outputs and the TV you want it connected to needs to have the video and sound inputs. depending on the distance between the 2 TV's this might prove to be rather difficult. it would be easier to run the coax cable from the main satellite box to the room where you have the 2nd TV however to do this you would need to move the satellite box back and forth. Hope this helps
Aug 22, 2017 | Televison & Video
Mitsubishi VS-60609 60" Rear Projection Television Logo
602 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
