Question about Epson Stylus CX4600 All-In-One InkJet Printer
Possessed epson stylus printer #cx4600
PLEASE HELP!!! I inherited this printer and it runs but won't print! I ran the head cleaner thingy and the jet cleaner thingy too,still blank paper. Epson troubleshooting suggested to let it soak over night,I did...still blank paper. I checked the ink level and it says it's down to half!!
HELP ME PLEASE!!!!!
Thank you,
Teresa Farley
  • sal0903 Dec 25, 2007
    Mine will not print at all (any colors) I replaced the ink cartridges several times. It shows the ink levels to be full but will not print. My son thinks that maybe dried up ink is clogging it between the cartridges & the paper.Is there any insight into this problem?
  • Anonymous Dec 28, 2007
    exactly the same problem
    Sergeant:
  • 310 Answers
I would suggest this http://www.supermediastore.com/cleaning-cartridge.html or a similar product from a different supplier..
Happy New Year
John
Posted on Jan 01, 2008
Epson stylus cx4600, not working
the printer wont work it will copy but not print anything off computer
Feb 01, 2010 | Epson Stylus CX4600 All-In-One InkJet...
Can not set up my new printer
Verify the port your pluging it into is connected and the Operating system reconize the printer by asking you to install drivers. there is a support page on www.epson.com that you can check out as well. hope this helps
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 02, 2009 | Epson Stylus CX4600 All-In-One InkJet...
I do not know how to make my printer work
it needs the complete service with the cleaning of head. it is better to perform the task professionally.
Dec 23, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Epson stylus cx4600 all in one
remove the printer inks & use soft issue paper to clean the printing head. how long have u be using this ink on the printer?. check for the ink level if its too low, the output will be very faint.
thanks. let us know if we should add more tips.
Oct 05, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Printer won't print
epson printers has a seprate printing head that holds the ink . when your inks are new & good .utilizes fixya repair directory to find a repairman to change the printing head for u .
Sep 07, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Lost my manuel !
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Pls dont forget to rate solution, thanks!!
May 02, 2008 | Epson Stylus CX4600 All-In-One InkJet...
EPSON CX4600 clogged
I have only just joined the forum but thought the attached may help.
I don't know the CX4600 so I'm only offering an idea.
www.hardwaresecrets.com/article/178/1.
Hope it helps
Feb 18, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus Printer CX4600
I don't know if this will work on an Epson, but it does on Cannon. The pads on the cartridges or the ink jets in the printer head may be cloged with dry ink. Get some Q-tips and rubbing alcohol (water is a poor substitute). Take out the ink cartridges and touch the pad on the bottom with a Q-tip (one for each color). If there is color the cartridge pad is OK. Take a fresh Q-tip dip it in rubbing alcohol and GENTLY rub the little holes on the bottom of the plastic box the cartridges go in. Thse are the print head jets. You should see color. You may need to clean it a couple of times if the ink has dried down into the jets. It is OK to have the Q-tip pretty wet, but not dripping.
Hope this helps
Dec 03, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Cx4600 epson
Jets are clogged Needs deep clean. 1st try -www,ssclg.com The Epson utility. Run the program- select your model- right click on the icon on the bottom task bar. 2nd Take a look at www.fixyourownprinter.com. 3rd make your own cleaning tool as here
May 18, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 all in one printer, scanner
Under Maintainance in the properties of the printer it gives you the option to clean the print heads. Should work
Feb 19, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
67 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
