2002 Hyundai Accent Logo
Posted on Aug 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hyundai stalls and will not start for several hours
Hyuandai elantra
  • Anonymous Mar 12, 2014
    I need to know whre to find timing marks for hyuandai elantra crdi 2.0
Jonah Oneal
Level 3:
  • Hyundai Master 14,092 Answers
  • Posted on Aug 27, 2009
Jonah Oneal
Hyundai Master
Level 3:
Answers
14092
Questions
0
Helped
7241723
Points
44533
MAKE SURE YOU HEAR FUEL PUMP RUNNING IF NOT REPLACE FUSE AND RELAY. CHECK FOR FUEL PRESSURE.IT SHOULD BE 43 PSI.IF NOT REPLACE FUEL FILTER.IF PROBLEM STILL EXIST FUEL PUMP THE PROBLEM.
BYPASS AN IGNITION SWITCH TO START A 2016 HYUANDAI ALANTRA
Cannot bypass ignition switch and start vehicle because of built in factory anti-theft circuit. Need to re-program ignition key - check with locksmith. Starter can be energized by jumping +12VDC directly to starter Ign terminal but no ignition spark will occur due to anti-theft system. Vehicle motor will turn over but engine will not start and stay running.
Timing marks for 2006 hyuandai elantra 4cyl
Go to YouTube, type Elantra Timing belt replace. There are a few videos that will show cam and crank timing marks. Very helpful stuff.
Good luck
2003 hyuandai elantra need to kniw how to remove starter automatic transmisssion
Youtube has some good how to videos, do a search there. Usually there are two main bolts and the electrical wires that need to be removed.
The car keeps stalling splutters then stops running
Hyundai Elantra Questions - Engine stalls / hesitations at ...
www.cargurus.com > Questions > Hyundai > Elantra
CarGurusApr 20, 2013 - Engine stalls / hesitations at idle and low acceleration - Model: 1999 Hyundai ... stopped... and then at one last desperate pump of the gas pedal, the ...Despite all this, most of the time, the car runs smoothly, and several shops have .....Keep in mind that my car is Elantra 2001 with 82k miles on it, the car will ...
My car keeps shutting off when idle.. - CarGurus
www.cargurus.com > Questions > Chevrolet > Impala
CarGurusFeb 15, 2013 - whenever im on breaks or, it stutters for then cranks right back up. ... of your question, the stalling, hopefully somebody will come by to help you on that. ....Car having trouble starting,rough idling,shutting off at stop 2 answers.
How to Fix a Car That Stalls: 7 Steps (with Pictures) - wikiHow
www.wikihow.com > ... > Cars > Car Maintenance and Repair
wikiHowThere are many things that could cause a car to stall. ... Your engine stops runningbecause it is not igniting gas in the cylinders, this occurs either because there ...
I have a 2004 hyundai elantra. it has been over heating and last night it stalled out and now it will no start. any ideas what it may be.
well thats because you got the spelling wrong its honda not hyundai get it right HONDA,,,,,,,,,,,,,,
3helpful
Hyundai elantra diesel wont start. the immobilser
i have a hyundai elantra, 01, diesel. it was running grand, i knoch it off for an hour, came back, try to start the car, but no way would it start. what is wrong with it
I HAVE A **** SIZED DENT IN MY 2005 HYUANDAI'S DRIVER'S DOOR - WANT TO KNOW HOW TO BUMP IT OUT
Hire a paintless dent repair guy. if it can be done he will know how to do it without messing up the paint
Hyuandai high idle speed when in traffic
You don't, unless it's ridiculously high, like over 1750 rmp. Most cars will idle higher in drive then they do in park. The next time you get caught at a light put it in park and let it sit, it may go higher at first but most lower below what it was idling.
'01 Elantra Start-up issue
i think you should change the fuelfilter.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
