Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
LSE7806A Top Load
I have a stack maytag lse7806ace.the dryer works fine and the washer fills,aggitates and goes through the timer
,buy in the rinse spin cycle it trips the overload for a minute.i replaced the timer.still same thing .i removed the belt from the drain and still trips overload.all othe functions seem fine
  • marcer Dec 05, 2007
    oops i clicked the accept button instead of reply.ehat do i do if the brakes are stuck
  • 447 Answers
The belt is still attached to the transmission right?? It sounds like the brakes may be stuck. Or are both belts off and the motor still trips out?
Posted on Dec 05, 2007
  • joey  shearer
    joey shearer Dec 05, 2007
    The motor reverses for agitate and spin funtions. There is a cam in the lower pulley assy that raise the brake pressure plate off the brake stator. Remove belt from transmission and check in spin to see that motor reverses fine and is bound by the tranny in spin. Next attempt to spin transmission pulley in spin direction and see if pulley raises up releasing brakes. If brakes seem stuck ie pulley rises as if to release and then is bound, manually rotate spin tub by hand or you can spin the conical bellhousing of the tranny. If tub still wont free than we will go further.
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Maytag stacked washer dryer lse7806ace
Take the belt off the transmission pulley and see if you can turn it by hand. It will agitate on direction and spin when you turn it the other direction.
Put the timer to spin with the belt off and see if the motor will run. There may be a problem in the start switch on the motor letting it start in one direction but not in the reverse direction.
Special tools are required to remove the transmission and brake assembelies. You also want to make sure there is nothing sticking through the holes in the basket causing it to lock up such as a nail or screw that may have been left in a pocket.
Post back with what you find.
Thanks/Mike
Dec 05, 2007 | Maytag LSE7806A Top Load Stacked...
Top Load Stacked Washer / Dryer Maytag lse7806ace -- washer will not run, except in spin cycle
I believe there is a fuse on the left side front under the front panel about a foot from the top of the washer.
Nov 20, 2010 | Maytag LSE7806A Top Load Stacked...
Washer won't drain or spin
YOU MIGHT BROKE THE DOOR SWITCH CHEC IT OUT FIRST... IT CAN BE BYPASS IF YOU WANT :) LET ME KNOW
Feb 21, 2010 | Maytag LSE7806A Top Load Stacked...
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag washer lse7804a won't fill
with the timer in the wash position on any cycle do you have 120 volts on the selenoids that the water hoses are connected to with the temp selector set for warm wash and timer knob pulled out? if you do then the water inlet valve is the issue, if no voltage you could have gotten a defective timer
Apr 10, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
306 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
