Question about Casio Cassiopeia E-125 Pocket PC
Lost data? My Cassiopeia E-125 doesn't turn on. The amber light just blinks once as I connect the power transformer directly to the PDA. I left it unplugged / uncharged for about a week. It won't take a charge now. I understand it probably will work with a new battery. anyway to save/retieve data?
  • 3 Answers
Leave the backup battery in the PDA and bring it back to life with this how to ;)
http://youtube.com/watch?v=l0TT5CnbwBQ
if that doesn't help you may need to give the battery a little kick-charge for the PDA to recognize it again. the PDA "thinks" there's not battery if the battery voltage is below 2Volt.
to "kick-charge" the battery just get a AC adaptor with at least 5V and 1A (a.k.a. 1000mA) with 2 wires and connect them to the battery pins (with "+" and "-" correct!)
if you have your PDA lying in front of you with the display down and the battery cover opened, the pins of the battery are as following:
left: plus
middle: charging/temperature (not important for hand-charging)
right: minus
connect the wires of the AC adaptor correctly and let it "kick-charge" for about 5minutes (but NEVER let it charge any longer if the battery is getting hot!!!!)
after that, the PDA should recognize the battery again because the voltage is more than 3Volt again.
but don't (!) try to power it up after kick-charging!
the batterys voltage is higher than 3Volt again, but it takes just a few seconds to empty it again if u try that.
it's only for the PDA to "see" the battery again ;)
Posted on Jan 15, 2008
Cassiopeia E-125
I had the same problem with an E125 which I brought off eBay that hadn't been used for several months.
I took out the backup battery and put the main battery in it's holder with a bare wire held onto the negative & positive terminals.
When I turned on the charger, I held the other end of the bare wires onto a partly charged Nokia Battery (Also 3.7V internal). The current from this battery was enough to let the Casio start charging.
After two minutes I disconnected the Nokia battery and gently tugged the bared wires free. The Casio kept on charging happily.
After six hours I disconnected the AC charger, installed a new backup battery CR2032, and everything was go.
Aug 25, 2007 | Casio Cassiopeia E-125 Pocket PC
My Cassiopeia came with a 4 digit pass code on it from another user how do i get that off of the computer so i can use it
Casio claims that once a password has been set in your unit it can't be reset without losing all data. You can try resetting and see if that works. Use ur stylus and press the reset button for about 3 seconds.
Dec 23, 2006 | Casio Cassiopeia E-125 Pocket PC
When charger is plugged, amber light blinks once and then nothing? E125 not working at all!
The Casio PDAs will quit charging very quickly if the battery is very, very discharged. If you continue to remove and re-insert the charger into the PDA's power socket, the recharging cycle will last longer and longer until finally the stupid thing will fully recharge its battery.
I have two Casio PDA's and three batteries that were recovered after a bit of tedious struggle to force the charging cycle to complete.
Jun 02, 2006 | Casio Cassiopeia E-125 Pocket PC
Casio e-125 problem
Sounds like you might have a bad cable or something. Did you try plugging ppc into its power pack while using the cable?
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
My E-125 isn't working properly...
If your craddle has DC power input that charges the PDA while in craddle, try setting the power configuration so that when the PDA is on external power, there is no blank screen timeout, and no automatic shutdown (it's in the Settings menu). This way, it won't power down while in craddle, and you won't get this problem you're having.
E-125 Will not power up ??? HELP
i made a video how to fix your dead Casio Cassiopeia PDAs.
AFAIK it works on the following models:
Cassiopeia E-10 (AFAIK)
Cassiopeia E-11 (AFAIK)
Cassiopeia E-15
Cassiopeia E-100
Cassiopeia E-105
Cassiopeia E-115
Cassiopeia E-125
Cassiopeia E-55 (= Japanese Version of E-15)
Cassiopeia E-5xx (Japanese Versions of the E-1xx Series)
Maybe it's also applicable to the EM-500 and EM-505 ...
and read the description pls :)
Casio E-125
Blinking amber light means the battery is not fully recharged. Once it is charged, press the power button. If the the device still does not turn on take out the main battery and the backup battery. Put the main battery in first, then the backup battery and put the battery switch in the lock position. Press the power button and you should see initializing memory..., then starting..., then it will ask you to set up the device.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
E-125 connecting to Siemens ME 45
There are 2 things you could try. If you have a serial data cable for both the devices try using a nul modem (Casio part # SB-91 includes best nul modem ever made ) & select Hayes compatible on serial port on E-125. If you have a built in modem in ME-45 it should work. Similarly you could use MS Outlook as an intermediary for transferring your E-125 telephone numbers to ME-45.
Open Questions:
Casio Cassiopeia E-125 Pocket PC Logo
277 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
