Question about HP Compaq nx6110 Notebook
Traveling to Brazil fearful of using 220v power outlets
What Should I do to protect my compaq nx6110 when having to use a 220v power outlet?
  • 39 Answers
Where u ll be in Brazil. In São Paulo the default voltage of power outlets is 100v.
Here in Brazil the ac adapters comes form factory bivolt (110/220)..
Didnt understand your fear..
send me an email if I can help u. Im brazilian and I live in Osasco-SP.
Good luck in your travel
Posted on Dec 15, 2007
How can I wire a 110 outlet to a 220 outlet?
If the bed is a 220 volt, you can only use a 220 volt outlet.
If the bed is 110/220 you should check the web for specs and wireing.
May 31, 2014 | Health & Beauty
Puts put power on the 110V outlets but not the 220V outlet
check the changeover switch and wiring if that's ok then you will need to check the coils on the alternator when using 110 it runs both coils in parallel but when using 220v it runs both in series if one coil is out you will get nothing
Oct 27, 2013 | Coleman Electrical Supplies
Generator 4 prong220v outlet to 3 prong 220v plug
Go to your electricians store and ask if they have a converter plug, Don't go to a Homedepot type place, go to the specialty place where electricians go. Their depth of knowledge is way better.
Jul 13, 2012 | Electrical Supplies
How to use it if we have 220V outlet?
If the AC unit is 110V then you must plug it into a regular 110V outlet. You cannot plug it into the 220V outlet. Either get a bigger 220V unit or use a 12 gauge extension cord to get it to a 110V outlet.
Sep 06, 2011 | Haier Mechanical Air Conditioner HWF05XC7
Plugged my US made PC into a 220v outlet!
Hi
You need to change power supply unit. You can find a guide with screenshots here
May 03, 2009 | E-Machines eMachines Desktop PC
Problem with power cord/AC adaptor...maybe?
I would just go buy another battery charger pack. They are like 75 dollars to buy. Sounds like yours might have a short in it!
Mar 26, 2009 | HP Compaq nx6110 Notebook
Suzuki SE4000SED generator with no output
There was a day and time when generators were simple. There were no capacitors, regulators to control/adjust power to magnet or ground fault outlets. Winding getting hot indicates short, however could be bad capacitors. Rectifiers and capacitors must be removed from circuit to test properly. Here is a simple test that I use to find fault area. I use a small power supply (16v AC 1 amp like doorbell transformer) into the 110v outlet of generator. This should energize the armature magnet and actually produce voltage at commutator with brushes pulled off. You can slowly pull the starter rope to move the armature into a different positon the voltage will vary. If the ac windings are shorted there will be very little or no magnet. There is a seperate 110 v circuit at the 220v outlet to test (there are two 110v windings that make up the 220v outlet, one is also used for the 110v outlet). There is another winding that products voltage for the regulator that powers the magnet thru the brushes but I think that circuit is porbably working because of the heat in the windings. You might even have 110v power at the 220v outlet. As our parents told us over and over, be careful when working with electricity. Enjoy
Dec 06, 2008 | Electrical Supplies
Hp 65w adapter compatibility
no it will burn the power supply if half wave rectifier is used in adapter then it may work if you are not technical person then purchase new adapter or convert it from any technician
Nov 19, 2008 | Computers & Internet
Plugged into 220V outlet by mistake! Help!
I don't know for sure, but I suspect that if you open it up, there should be a fuse near the power supply portion of the unit. It may have taken the hit for you and can perhaps be replaced easily. (As a disclaimer... be sure the unit is not plugged in when you open the case! And only replace the fuse with another of equal rating.) If it's not a fuse, then you probably smoked the primary winding of the transformer. If it got past that, you may have popped the rectifier and/or capacitor(s) in the power supply.
Oct 20, 2006 | Technics SA-DX930 Receiver
HP Compaq nx6110 Notebook Logo
198 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
