Question about HP Photosmart C3180 All-In-One InkJet Printer
Faxing on HP C3180
I don't know how to send fax
When you are ready to send fax hold down the ctrl button and the P button at same time it will ask you if you are ready to print look at the window that comes up, make sure that you click FAX not Print then you should be in good shape. Good Luck,
simpleman40@msn.com
Posted on Dec 05, 2007
2 Suggested Answers
JackHeath
  • 1049 Answers
SOURCE: MY HP LASERJET 3050 WON'T SEND FAXES
While its possible, I doubt your doing it wrong...
  • Select [FAX], place the paper as indicated on the tray, type the number, and hit send. That's about it.
However, Fax machines will not send when attached to a digital phone network, used over IP phones, or in conjunction with DSL service without the lines being conditioned. This is a small device which hides the higher frequency noise from the fax machine. Any sort of signal shared on the lines may interfere with sending, recieving, or both. If you use DSL for example, I'd almost guarentee this is part of your problem.
Posted on Aug 01, 2008
Lost my manual and don't know how to send a fax. Not sure which tray the document goes in. Can you help?
Directly from HP's manual on this printer:
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
For more assistance with this printer, you can go to http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=441125& and download the owner's manual. It is in PDF form, so you will need adobe reeader which you can get for FREE at http://www.adobe.com
Rose Marotta
PC ICU
Danville, Va 24541
For all your computer repair needs.
Jul 11, 2011 | HP Officejet 5610 All-In-One InkJet...
I can't open Fax services in HP Solution Center ,so I can't use fax function
This printer model, has no capability to FAX, it can only "Print/Scan/Copy". Hence the Solution center has disabled the faxing option.
Please refer product specification @ http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00649946&lc=en&dlc=en&cc=us&lang=en&product=1146331&key=null&site=null
Dec 18, 2010 | HP Photosmart C3180 All-In-One InkJet...
I want to know how i can use my copy machine to a fax so i can use it for incoming or outgoing?
Install software
Make sure all cables plugged: phone cable, USB cable to computer
Send fax from computer:
- print your document to printer HP .... FAX
Send "traditional" fax:
- put your document into scanner input
- type phone number on HP Officejet keyboard
- push button "Send"
If your HP Officejet if connected to phone line, it reseiving faxes automatically.
Hope this helps
Nov 12, 2010 | HP Officejet 4215v All-in-One Printer
I'm trying to scan in a document and then fax it using HP Photosm
Unlike most scanners, you must put the page that you want to copy in lower right corner of the glass (notice the small arrow pointing to the corner). This should fix any problem with an image being cut off. As far as faxing, I don't think the C3180 is able to fax pages. Hope this helps
Feb 05, 2009 | HP Photosmart C3180 All-In-One InkJet...
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
If you need printed confirmation that your faxes were successfully sent, follow these
instructions to enable fax confirmation before sending any faxes. Select either On
Fax Send or Send & Receive.
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send &
Receive
Prints a fax confirmation report for every fax you send and
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Fax machine
1)Disconnect the power cord from the rear of the HP Fax machine.
2)Verify that the phone cable is fully inserted into the fax machine. If your model has a removable Line Interface Unit (LIU) where the phone line plugs into, verify that it is securely snapped in place.
3)If the HP Fax model belongs to the HP Officejet R80 Series , verify that the cable which goes from the Automatic Document Feeder assembly to the rear of the HP All-in-One base is connected.
4)Reconnect the power cord.After the fax reinitializes and it is ready, try to send and receive faxes again.
Sep 15, 2008 | Office Equipment & Supplies
Send fax using pc
Please perform the following steps to fax from PC.
Click windows-->Programs-->HP-->HP Solution Center
Clik on Send Fax and provide the number of the fax to be sent and proceed with the steps to resolve the issue.
Every application has the option of sending fax from the File Menu---> Print-->Select the Fax icon and click on Ok.
Jan 05, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
135 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
