suggest you check main battery and connections, then check fuse box and fused relays. replace or repair any suspicious components, check alternator output,
Take off the top of the front loader, topfrontleft is the dispenser, there is a movable part that was incrusted and unablble to freely move, clean off parts, little water will do, the movavable piece should move back to the roman numeral one, it is spring loaded, put top back on, done.
firs try to put the key on the on position and then off befor starting few times this will help pump the fuel to the engine and help it to start . second use antifreez , special type of oil if your weather is mostly cold ,
you really cant ,,i would just let it dry,,this is why,,because any product that will remove the ink will aslo remove the enamel,,and with out that coating ,,your chothes will get gray stains from the raw metal once the ink dryers it will not come even on the white clothes...
