when adding volume on amp protection light blinging have 4gauge wire on amp. have a 800 cranking amp diesel battery also a 5farat capasitor on system. what should i do to stop dat problem.
With a 5500 watt amplifier you should be running 0 awg wire . You also need to be running an anl fuse holder with a 250 amp fuse underneath the hood by your battery. When the power light blinks like that it means that it needs more power - ie. that there is resistance some where in the system . With 4 gauge wire it just isn't getting what it needs. Make sure you upgrade the ground as well to 0 awg . If you have any other questions please feel free to contact me mmaudio545@yahoo.com
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
YOUR ADVICE WAS VERY HELPFUL THANK YOU !
" - roger_b14
your answer down there describes to me really well what subsonic is, but is it better to keep it...
(More)
your answer down there describes to me really well what subsonic is, but is it better to keep it high or low on your amp. what will it do???
muy buenos dias ante que todo tengo una kicker kx 1200.1 le quitaron los transistores mosfer y...
(More)
muy buenos dias ante que todo tengo una kicker kx 1200.1 le quitaron los transistores mosfer y quiero saber cuales son los modelos o por lo menos el diagrama gracias
