Question about Samsung HLN617W 61" Rear Projection HDTV
Samsung DLP 43 rear projection
I took my tv to a svc center to have the color wheel replaced, it comes to be that i had a wire broken that was attached to give power to the TV. Now the svc center cannot find a part number or part for it. Where can i find wiring part numbers? without taking it from svc center to svc center.
  • 87 Answers
Go to an authorized Samsung center. Part #'s are easy for us to find. Is the wire from the color wheel the broken one?
Posted on Jan 03, 2008
I have a 43 inch samsung DLP tv 2004 model# HLN4365W, I was getting a black and white picture, so i replaced the color wheel which was broken. It worked fine for a couple of days then there was no picture,...
No picture on a DLP when you can see the lamp is working is ALWAYS the DLP chip. BECAUSE you recently replaced the color wheel, i suspect that the LVDS/data cable to the light engine was not plugged in well and has come loose. I suggest checking and rechecking every cable and plug you can find.
Aug 09, 2012 | Samsung HLN4365W 43" Rear Projection...
I took my Samsung HLN507W apart to replace the color wheel fan... is there a schematic somewhere in the TV or online so I can now put it back together?
You Tube have video by somebody take out the old colors wheel and steps by steps and a replacement of a new colors wheel put into the DLP tv.
May 08, 2011 | Samsung HLN507 50" Rear Projection...
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
PICTURE STOPS & DETERIORATES THEN GOES BLACK. WHEN I TURN SET OFF I GET A WHINING SOUND (FAN?) FOR 20 SEC. & THEN SET TURNS OFF
The sound comes from the color wheel and not a fan,common to samsung dlp tv's which can be the cause of the shut down.
Mar 22, 2010 | Samsung HLN4365W 43" Rear Projection...
My Samsung 56 DLP picture lost is color and is making a buzzing noise which I suspect is the color wheel. The picture is now black
you need to change the color wheel
5
6
7
8
Feb 07, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Picture suddenly went out and the lamp and temp lights in front circle are blinking.
Hi,If your tv is between 2-4 yrs most likely it's time to replace the lamp.If you hear continuous clicking it could be the ballast which is the board that powers the lamp.If you hear buzzing it could be the color wheel,which is a spinning wheel that creates the color on your tv.God bless you!
Oct 13, 2009 | Samsung HLN4365W 43" Rear Projection...
How do I change the color wheel on my samsung HL-P5663W. I have already removed the lamp and loosened screws for the lamp housing. Doesn't seem to want to come apart. Am I on the right track?
5
6
7
8
Jul 10, 2009 | Samsung DLP HL-P5663W 56" TV
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
COLOR WHEEL REPLACEMENT
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
I replaced my color wheel on this TV using those instructions.  Took me about an hour but it worked perfectly.  Just take your time.
Aug 15, 2008 | Samsung HLN5065W 50" Rear Projection...
Hlp4663w color wheel
Check
Jan 29, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLN617W 61" Rear Projection HDTV Logo
63 people viewed this question
Jerry Greenberg
Jerry Greenberg
